Misses when hot
https://www.ausmini.com/forums/viewtopic.php?f=2&t=50043
Page 1 of 2
Author:  Blokeinamoke [ Sat Feb 07, 2009 8:04 am ]
Post subject:  Misses when hot
After much children delivery to multiple sporting events throughout Sydney - at high speed as they were late :roll: , the Moke developed a miss at high revs when hot.
Any suggestions?
Author:  Flute [ Sat Feb 07, 2009 8:09 am ]
slow down? Sorry, that's not very helpful but I couldn't resist. I had a similar problem that turned out to be a blokage in the SU's and I discovered there was no filter. It only seemed to happen in similar conditions to yours. Just a possibility to investigate.
Author:  sports850 [ Sat Feb 07, 2009 8:16 am ]
Electric or mechanical fuel pump ? I've had a mechanical pump start to fail on stinking hot days and lead to slight fuel starvation , was just enough to cough occasionally . There's a lot of heat trapped at the back of the motor on hot days ...
Author:  Blokeinamoke [ Sat Feb 07, 2009 8:33 am ]
electric fuel pump
Author:  mini-dunger [ Sat Feb 07, 2009 9:43 am ]
I had a similar problem the other day with my chain saw. I worked out that it was old fuel. Put some fresh stuff in and it was fine.
I know this dont help but it just made me think of it.
Author:  Blokeinamoke [ Sat Feb 07, 2009 9:50 am ]
nup - new fuel
I just did the last run for the day - so I will rest it try with fresh plugs
Again it missed with load at lhigh revs - no miss on light load
Author:  sports850 [ Sat Feb 07, 2009 9:53 am ]
Does it run on when you stop after it's been missing or is it behaving itself otherwise , not running hot at all or anything else ?
Author:  Blokeinamoke [ Sat Feb 07, 2009 10:01 am ]
nup doesnt run on - generaly behaves itself - it runs a little hot but that is due to hills around here
The poor little Moke had been running up and down these all morning loaded to the rafters
Author:  speedy [ Sat Feb 07, 2009 10:05 am ]
Damn, I thought this thread was about your missus when she's hot. :( :lol:
Author:  Blokeinamoke [ Sat Feb 07, 2009 10:09 am ]
I thought that you would think that when I posted it. I see the way you look at her :P
Author:  phillz [ Sat Feb 07, 2009 10:19 am ]
any oil leaks around the electrics or plug leads, oil starts to run when it gets hot and can short things out.
Author:  Blokeinamoke [ Sat Feb 07, 2009 10:21 am ]
nup - but good enough idea to get off my butt and check
Author:  speedy [ Sat Feb 07, 2009 12:10 pm ]
You've confused with me with Tiny. :cry: :lol:
Author:  Stuwey [ Sat Feb 07, 2009 3:09 pm ]
There's a guy in the Sprint rounds here at Mallala with the same issue in his Cooper S faker. Been hunting it for months and can't find it. If he lets it cool between sessions - its fine. But as the laps progress, the misfire gets worse and worse..
Let us know if you do figure it out!
Author:  drmini in aust [ Sat Feb 07, 2009 3:26 pm ]
Check what coil is on it now, if it's a resistor coil running without one they get hot then do just that.
Try another coil, 12V. :wink:
