It is currently Mon Jul 14, 2025 8:54 pm
 Post subject: jumps out
PostPosted: Tue Feb 10, 2009 6:49 pm
hello all my clubman has started 2 jump out of 2nd gear ,this only happens under hard deaccaleration is this a problam with links ,engen mounts/stays or is it something more sinister, if ihold the gearshift it does not happen . wher should i start????
PostPosted: Tue Feb 10, 2009 6:56 pm
High heel ninja
Worn syncros are the usual suspects, gearbox may need a freshen up.
Doogie
Tomboss Breweros
Bad news bro, 2nd syncro will be worn, and possibly 2nd gear itself. Not too cheap. :cry: Common :cry:
kimini wrote:
Jimmyinamini wrote:
 Post subject: Re: jumps out
PostPosted: Tue Feb 10, 2009 7:57 pm
The Mini King
If it is a Rod Change Gearbox the first thing I would do is check ALL the external linkages for wear, and the gear stick aswell,
PostPosted: Tue Feb 10, 2009 8:40 pm
It could also be the 1-2 selector fork is worn bad, or cracked. They do get a hard time...
PostPosted: Tue Feb 10, 2009 8:58 pm
The mini king is on the ball, worn engine steady bushes, engine mounts, r cotton reel mounts and the rod change sleeve & roll pins all can cause the gearbox to jump out of gear. Check & fix all these items before you start pulling the gearbox apart. Broken springs in the hubs are a common cause of jumping out of gear once you get into the gearbox.
David.
Have a Nice Day.
PostPosted: Tue Feb 10, 2009 10:07 pm
it is a rod change setup. have just been driving and have noticed that it will jump out 2nd ideling at 20kph if you hit the right bump dont know if this changes any ones reply ? il go check out links and all rubber and plastic bits thanx 4 the advice
PostPosted: Wed Feb 11, 2009 6:41 pm
mine tends to jump out of fourth every now and then.. should i be checking the same things? or because its fourth gear could it be something else?
PostPosted: Wed Feb 11, 2009 8:25 pm
The Mini King
Yes I would check all the previously mentioned items
