It is currently Wed Jul 30, 2025 6:06 am
 Post subject: Diff bearings
PostPosted: Sun Feb 15, 2009 9:05 pm
can i change the diff bearings and side cover bushes with the engine in the car??
or can the diff only be removed with the engine out?
i noticed there if a fair bit of slop in the bearings causing oil to leak out the side cover seal
Regards,
Matt
PostPosted: Sun Feb 15, 2009 9:08 pm
That slop is not the diff ball bearings, it is the bronze bushes in the side covers.
Yes you can fix this in the car, you need to drain oilz, remove covers, press new bushes into the covers, then get their bores machined to fit your pot joints/output yokes.
PostPosted: Sun Feb 15, 2009 9:10 pm
thats what i like to hear
an easy cheap fix
thanks
PostPosted: Sun Feb 15, 2009 9:21 pm
I wondered about that rh pot joint. the left was ok but the right hmmmm
As doc said if you need new one ,get one and bring it up and I will fit and machine it for you. bring the pot joint as well.
At least it runs better than the 1275
www.minisprintgt.com
PostPosted: Sun Feb 15, 2009 9:24 pm
Tomboss Breweros
Do you think the boring could be done on a lathe? Or would a mill be best?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Feb 15, 2009 9:34 pm
definately on a lathe. a mill is not designed for that type of job.
when matt put the pot joint in he may have dislodged the seal spring
PostPosted: Sun Feb 15, 2009 9:39 pm
hmm thats a point and chance that spring could make its way past the bush and do some damage?
PostPosted: Sun Feb 15, 2009 9:41 pm
I doubt there is room for the spring to get past the bush.
Clearance is only .001" approx when new.
PostPosted: Sun Feb 15, 2009 10:06 pm
Your right there doc. the gearbox is A plus , and matt changed the pot joints over. the original rh one was loose when I checked it.
The other joints are worn as well so it probably needs new bushes. Matt put it in and I just wondered if he dislodged the seal spring. Unfortuneatley I did not get chance to check it over after they were fitted as I had to go out.
He has put this second hand 998 eng /box into his car until he rebuilds his 1275. It was a rush job.
PostPosted: Sun Feb 15, 2009 10:27 pm
for a rush job the engine is great.
just got the one little issue so far.
but ill do the right thing and fix it this week.
Users browsing this forum: Bing [Bot] and 15 guests
