It is currently Mon Jul 28, 2025 6:58 am
PostPosted: Sat Feb 14, 2009 4:16 pm
Got the pressure reducer thing off and pulled apart - full of crud - note there are two rubber seals - are these replaceable ie can you buy them anywhere? - not seen them in my travels.
Also Matt Read - I've misplaced your distructions on how to make the unit adjustable - I know there is another version about on the web but I remember I liked yours best - Can you do a 'How too' please?
PostPosted: Sat Feb 14, 2009 4:30 pm
kit p/ns are ssb602 & ssb603 from memory,,, one is for the std mini & the other is for the "S" valve,,, forgotten which way round it is :-)
& drill a hole into the back of it,,, thread the hole,,, have bolt of same thread handy & weld a lever to it,,, trim the pring down a coil or 2,,, fit a flat washer of correct size to fit into the cyl before re-fitting newly kitted valve spring & piston assy,,, add lock nut with (lever welded to it) onto the bolt before fitting & you can add an o-ring to help seal it if you so desire
i think we used to use a one cent piece as the flat washer years ago :-)
PostPosted: Sat Feb 14, 2009 4:39 pm
Got a jar full of them :wink: Thanks Matt
