Rear brake pressure equalizer thingy https://www.ausmini.com/forums/viewtopic.php?f=2&t=50280 |
Author: | Wombat [ Sat Feb 14, 2009 4:16 pm ] |
Post subject: | Rear brake pressure equalizer thingy |
Got the pressure reducer thing off and pulled apart - full of crud - note there are two rubber seals - are these replaceable ie can you buy them anywhere? - not seen them in my travels. Also Matt Read - I've misplaced your distructions on how to make the unit adjustable - I know there is another version about on the web but I remember I liked yours best - Can you do a 'How too' please? |
Author: | TheMiniMan [ Sat Feb 14, 2009 4:30 pm ] |
kit p/ns are ssb602 & ssb603 from memory,,, one is for the std mini & the other is for the "S" valve,,, forgotten which way round it is ![]() & drill a hole into the back of it,,, thread the hole,,, have bolt of same thread handy & weld a lever to it,,, trim the pring down a coil or 2,,, fit a flat washer of correct size to fit into the cyl before re-fitting newly kitted valve spring & piston assy,,, add lock nut with (lever welded to it) onto the bolt before fitting & you can add an o-ring to help seal it if you so desire i think we used to use a one cent piece as the flat washer years ago ![]() |
Author: | Wombat [ Sat Feb 14, 2009 4:39 pm ] |
TheMiniMan wrote: i think we used to use a one cent piece as the flat washer years ago Got a jar full of them ![]() ![]() |
