molasses rust removal
https://www.ausmini.com/forums/viewtopic.php?f=2&t=50305
Author:  TUCK3r [ Sun Feb 15, 2009 1:55 pm ]
Post subject:  molasses rust removal
hi
i have just pulled my 1275 block out of a tub of molasses after sitting it in for around 2 weeks and it has come up very nice no rust in the inside of the engine at all. i forgot to knock the welsh plugs out so did that today and ill put it back in for another couple of weeks and see how i go. id recomend it to people that are going to send there block away to get chemically cleaned as its much cheaper as i payed $20 for 20l of molasses.
TUCK3R
Author:  TurboOrangie [ Sun Feb 15, 2009 3:30 pm ]
I built an electrolytic rust removal tank, it cost me about 5$ for a box of washing soda. I already had a bucket and some scrap sacrificial metal and a battery charger. You might want to make one, it takes hours instead of weeks to accomplish the same thing.
Author:  TUCK3r [ Sun Feb 15, 2009 3:52 pm ]
yes thats a good idea but times not and issue for me. how does electrolytic rust removal tank work is it just water and washing soda and electrolysis?
TUCK3R
Author:  TurboOrangie [ Sun Feb 15, 2009 4:04 pm ]
You got it, pretty simple, negative goes on the piece you are removing the rust from and the positive goes to the sacrificial metal.
Author:  drmini in aust [ Sun Feb 15, 2009 4:39 pm ]
We built one of these for work, used a council 200L `Otto' wheelie bin for the tank. :D
The positive goes to a bar of 304 S/S on this one.
I dunno how well this would work for getting internal rust from the water jacket though, where molasses does a great job. :wink:
Author:  TUCK3r [ Sun Feb 15, 2009 4:42 pm ]
do you think it would still work if you did the method you said but instead of water you use molasses?
TUCK3R
Author:  John Smidt [ Sun Feb 15, 2009 5:28 pm ]
I would think that inside the block would be very low current density areas,
If i use this method I usually make the Part the Anode and the Plate Cathode On ferrous Metals, Using an Alkaline Electrolyte
Author:  bamnfi [ Sun Feb 15, 2009 7:37 pm ]
Hey John, that blew me away!!!!! End of debate stuff that.
And, btw, thx.
