Steering Rack https://www.ausmini.com/forums/viewtopic.php?f=2&t=50332 |
Author: | belgord [ Mon Feb 16, 2009 7:42 am ] |
Post subject: | Steering Rack |
my steering rack is buggered. are the ones from minisport anygood? Are they a straight up swap in out job? My mechanic will be doing this, and I will be helping. So i dont bugger it up hehe http://www.minisport.com.au/prod61.htm Its to go into a 1967 Morris Mini cheers Brendan |
Author: | poeee [ Mon Feb 16, 2009 7:53 am ] |
I'd buy that if mine was stuffed. ![]() |
Author: | BALLISTIC [ Mon Feb 16, 2009 8:33 am ] |
Yeah they are are straight swap........remember that you HAVE to drop the subframe away from the body for removal and installation, its a fun job ![]() |
Author: | jess [ Mon Feb 16, 2009 8:53 am ] |
as Matt (NAV) said to me when I told him about your mini Brendan "Thank god i'm not doing that, it's a BEEEEEEEEEEEEEP of a job" ![]() |
Author: | poeee [ Mon Feb 16, 2009 9:01 am ] |
BALLISTIC wrote: its a fun job
![]() Sure is ![]() |
Author: | frednutz&co [ Mon Feb 16, 2009 5:17 pm ] |
enjoy ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | drmini in aust [ Mon Feb 16, 2009 5:57 pm ] |
It's not that bad, even with hydro (like mine is). Main thing to remember- try the two U-bolts in the floor from above first, squeeze em in a vice until they fit in easy. They tend to widen out in use. ![]() |
Author: | John Smidt [ Mon Feb 16, 2009 6:10 pm ] |
Please Do not forget to Put The column on the Rack Then bolt column to dash Then Tighten U bolts Up Last, Oh And Check the splines on your column before putting back on |
Author: | Tombo [ Mon Feb 16, 2009 6:46 pm ] |
When you lower the subframe be careful not to break the jet on the carb. |
Author: | gafmo [ Mon Feb 16, 2009 6:51 pm ] |
This link has helped many people already on changing a Steering Rack. Will have to do a How to shortly ![]() http://community.webshots.com/album/117738459JkCtax |
Author: | TheMiniMan [ Mon Feb 16, 2009 7:28 pm ] |
Thank you John Shmidt,,, you just saved me a whole heap of typing (hope fully) ![]() |
Author: | belgord [ Tue Feb 17, 2009 8:24 am ] |
thanks for all the help and replys. Im sure ill have a great time. Shall be a good learning experiance ![]() cheers |
