It is currently Sat Aug 02, 2025 5:16 am
 Post subject: Paint Removal
PostPosted: Sat Feb 14, 2009 8:29 pm
Hello all, any tips on removing paint off the body, just using paint stripper and stainless scraper at the moment, is it worth buying an orbital sander to do the job, i have been quoted $500 to have our brick shot blasted is that a good price? We have the shell on a home made pallet and wheels set up no subframes no glass all stripped off. Central Coast NSW
PostPosted: Sat Feb 14, 2009 8:30 pm
i wouldnt recomend sandblasting as it has a tendancy to warp mini panels.
PostPosted: Sat Feb 14, 2009 8:33 pm
This space for rent
A thick coat of industrial paint stripper, and cover it over with the plastic wrap they use to wrap shipping pallets. Peels 99% of the paint like a banana.. you'll still need a wire wheel for the tricky corners though.
PostPosted: Sat Feb 14, 2009 8:37 pm
where can i buy industrial paint stripper? wot do u think to media blasting the shell?
PostPosted: Sat Feb 14, 2009 8:43 pm
This space for rent
Go see what a panel shop uses, and ask them where they get it.
I've never had a shell blasted, but from everything I've heard the expertise of the operator is critical. That said, Lindsay Palmer hereabouts had a shell soda blasted recently with good results so it's horses for courses.
PostPosted: Sat Feb 14, 2009 9:09 pm
Tomboss Breweros
Someone here on ausmini used paint stripper and glad wrap, i don't know where the thread is. Maybe someone else does.
I remember this - apply the stripper (the cheap one at bunnings works well) then put glad wrap over, drink beer for 30 min then lift off paint. The pictures looked good. 8)
A bloke at my work had about 1/2 of his clubby van steel blasted, yes the shot was tiny steel balls, and he had no warping.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Feb 14, 2009 9:15 pm
This space for rent
Skender, AKA 'Brown Clubman'.
Thread here
PostPosted: Sun Feb 15, 2009 12:04 am
Read this It is a great help http://www.ausmini.com/forums/viewtopic ... sc&start=0
PostPosted: Sun Feb 15, 2009 7:54 am
thanks heaps for replies and thread on paint removal, all go now!
PostPosted: Sun Feb 15, 2009 8:28 am
Penninsula Paints in West Gosford have the 4 litre cans of car trade paint remover.
Dave K.
PostPosted: Sun Feb 15, 2009 1:39 pm
i have been using paint stripper and glad wrap and its been going ok still need to spend a fair bit of time with the wire brush tho
PostPosted: Mon Feb 16, 2009 9:21 am
You can always use a wirebrush on an angle grinder it works very very well and would work out cheaper than paint stripper. I usd a wire brush for mine
PostPosted: Mon Feb 16, 2009 9:34 am
Make sure you have a ventalated area or a face mask if you are doing this. I did the Moke this way - slow going but the finish was good
