thermostat question.. 96C? https://www.ausmini.com/forums/viewtopic.php?f=2&t=50356 |
Author: | superSeven [ Mon Feb 16, 2009 6:46 pm ] |
Post subject: | thermostat question.. 96C? |
hi.. possible stupid question just about to install a thermostat in the mini (was an empty hole before)... anyway while reading the numbers on the new thermostat I noticed it had 96C on it.. does that mean it opens at 96C?!! Because I bought it as an 82C one... it's a columbus, part number (on the box) AS240180, and on the thermostat itself is stamped WTI 96C J6 180.. thanks, Tim. |
Author: | Morris 1100 [ Mon Feb 16, 2009 6:51 pm ] |
The important bit is the 180. 180°F = 82°C ![]() |
Author: | superSeven [ Mon Feb 16, 2009 6:55 pm ] |
bah! almost dark.. hopefully get this all back together tonight! thanks. so much! |
Author: | mini_mad_matt [ Mon Feb 16, 2009 7:30 pm ] |
And the number that its rated at means thats when its fully open yes? or is it when it starts to open? |
Author: | superSeven [ Mon Feb 16, 2009 8:30 pm ] |
another question.. this time about bottom hoses... the hose I got is the type for 1275 with heater. the main problem is that it seems to rub at the rear, against the firewall/brace.. do these hoses usually require a bit of trimming at the ends? I figure if I take 5mm off the top end of it it will bring it forward a little. |
Author: | drmini in aust [ Mon Feb 16, 2009 9:18 pm ] |
Yep if too long just trim a bit off. When they made em here, they were the right length... ![]() |
