Tachometer wiring https://www.ausmini.com/forums/viewtopic.php?f=2&t=50381 |
Author: | Jarred [ Tue Feb 17, 2009 4:27 pm ] |
Post subject: | Tachometer wiring |
Hey guys, Just bought a tacho and needed some advice on the wiring, i can do it sweet but then it says "green wire to RPM signal wire" well i don't have an rpm signal wire, it says to not put it to any positive terminal in the car so i was wondering should i put it to the negative terminal on the coil? or where in mini's with 3 gauge clusters with a tacho does the rpm signal wire come from? Cheers Jarred |
Author: | Tombo [ Tue Feb 17, 2009 4:39 pm ] |
Thats right, put the wire to the - on the coil. On a 3 guage the signal wire is on the rh end of the cluster, white with a color trace. |
Author: | Jarred [ Tue Feb 17, 2009 8:01 pm ] |
Thanks for the help mate ![]() |
