It is currently Wed Aug 06, 2025 11:28 am
 Post subject: a few questions...
PostPosted: Wed Feb 18, 2009 3:27 pm
Milatsmadmini
Ok.
having a really dumb slow day (nothing odd about that actually...) but in saying that i have a couple of questions...
1. Where does one mount an oil pressure line into the block :oops: (just got my dual gauge, water temp is all good...) just need to know where to mount into block,
2. Where would i find fittings for this oil pressure gauge? (both ends... and line as well...)
3. Got a lovely thermo housing with water temp hole in it... got a little rust in it. Could i soak this in something to clear it out before i put it on? if so what?
and finally,
4. Is it possible to mount (wire in) a clubby tacho into my 66 moke? (again, if so how...)
apologies for the lengthy-ness and noobness of post... :oops:
-Matt
 Post subject: Re: a few questions...
PostPosted: Wed Feb 18, 2009 3:43 pm
mattsmadmini wrote:
Ok.
flywheel end of the block, half way down
put a post in the wanted forum - you want the bits off a Mini K, or you can buy a gauge kit, but the thread mightn't suit your block...
don't do it - anything you soak it in will eat away the alloy, put a wire brush on the end of your drill and clean it manually
and finally,
too much pain, get an aftermarket one
-Matt
PostPosted: Wed Feb 18, 2009 3:45 pm
Milatsmadmini
Cheers Simon. :D
PostPosted: Wed Feb 18, 2009 3:55 pm
Milatsmadmini
In regards to tacho... what about something like this?
PostPosted: Wed Feb 18, 2009 4:01 pm
that one is dead sexy Matt though I wonder if you shouldn't be looking at something like these marine ones for the moke , http://cars.shop.ebay.com.au/items/?_nk ... acat=72535 , might be a bit more durable in an open car .
PostPosted: Wed Feb 18, 2009 4:04 pm
Milatsmadmini
definately noted.... wiring in may be an issue (im pretty bad at car electrics...) would it have to be calibrated for use on a car?
PostPosted: Wed Feb 18, 2009 4:06 pm
Someone else can confirm but any 4 stroke tacho that can be switched to 4 cylinder should do . a 2 stroke 2 cylinder one will be the same as a 4 stroke 4 cylinder too I think .
PostPosted: Wed Feb 18, 2009 7:34 pm
autobahn sell t-piece adapters (VDO ones) and oil pressure lines to suit smiths gauges. I bought a speco line which is copper? brass? but it's not one with the coil/spring around it so is prone to fatigue due to vibration. if you get one like this put a couple of loops at the end to dampen vibrations about 5cm or so from where it attaches to the block.
VDO make two t-piece adapters which makes things a little more confusing... take down your oil pressure switch if you can, so you can test the threads on the VDO parts.
do a search on here, there's a lot of information on installing oil pressure gauge and pressure switch.
tim
PostPosted: Wed Feb 18, 2009 8:58 pm
http://www.howardinstruments.com.au/
Have a chat to Roger he is very helpful. I'm sure there are recon Smiths gauges there too.
PostPosted: Thu Feb 19, 2009 10:04 am
Milatsmadmini
So i asked the seller about one of those tacho's that sports put up whether it could be used in a car.... here's the reply...
hi there, you just have to chag the pole settings n it to be for either 2 or 4 stroke
not convinced.... :?
ANd thanks for the link Scott... im lookin that direction now as well :wink:
PostPosted: Thu Feb 19, 2009 1:39 pm
Milatsmadmini
Alright.... went out and found the T adaptor.... couldnt find it at autobahn or supercrap or ripco.... just so happened i had to pick up a gift voucher for the missus brother at (american rare) Auto Spares, just outta the blue asked the guy at the counter (the owner... top bloke by the way...) "oh yeh sure... hang on a tick..."
Minute later brings back 2 Redline items...
RGA-31 Oil gauge adaptor 1/8in (a,b and c are all 1/8")
LK-1 Oil pressure gauge line kit. (to suit 1/8")
done and dusted for under 40 bucks, pretty happy with that :)
PostPosted: Thu Feb 19, 2009 2:42 pm
Milatsmadmini
Ok next question...
Does one need to empty engine of oil to install a new adaptor?
PostPosted: Thu Feb 19, 2009 2:48 pm
No , a little oil might dribble out while you're fitting it but it will be only minor , not enough to worry about .
PostPosted: Thu Feb 19, 2009 6:17 pm
Just dont have the engine running and you wont have a problem with the oil coming out :P
Users browsing this forum: Bing [Bot], misty-mk1 and 90 guests
