david rosenthal wrote:
As Matt suggested, use a angle grinder, but instead of using a grinding wheel on it, try a "flap disc".
was going to say the same... flap disk over the spots works well, you just peel the leftovers off with some pliers
I never use grinding wheels when doing panel work, the flap discs are a lot more friendly on thin metal
I tried to use a flap disk to smooth down the welds on a piece I repaired on a panel, and found the flap disk just thinned out everything - the metal around the repair was about .002" thick
did I tell you that I won a
trophy?
