It is currently Fri Aug 01, 2025 1:53 am
PostPosted: Sat Feb 21, 2009 7:59 am
Can someone post the correct method of installing the side trim finisher on Cooper S.
I have the right clips from John (MiniKing), but read somewhere that you start at one end (which one)? and unroll the strip a certain direction (not sure), and use a hair dryer to warm the strip around the tight bends (makes sense).
Can someone put more detail on this so no stuff ups.
I did think they were pop riveted on, but after talking to John, he said NO the correct clips should hold both flare and finisher strip always in place.
Steve
"Boris" - '69 Cooper S Mk 2
PostPosted: Sat Feb 21, 2009 10:15 am
You need to go to this thread,
http://www.ausmini.com/forums/viewtopic ... highlight=
I like my method best!
Dave
PostPosted: Sat Feb 21, 2009 3:51 pm
Thats the post I was looking for.
The straightening out approach (on the cloths line) seems the easiest.
I'll try that one.
Thank you
