Cleaning vinyl seats? https://www.ausmini.com/forums/viewtopic.php?f=2&t=50482 |
Page 1 of 2 |
Author: | mattsmadmini [ Fri Feb 20, 2009 12:35 pm ] |
Post subject: | Cleaning vinyl seats? |
Spray and wipe is going alright... a little slow though What would everyone suggest? |
Author: | Tombo [ Fri Feb 20, 2009 12:37 pm ] |
Go to a auto store, in the polishing section find the Autosol metal polish, near that you should find Autosol vynil cleaner in a blue tube. Works really good on plastic too. |
Author: | brett [ Fri Feb 20, 2009 12:53 pm ] |
Meguireres Dash cleaner its a foam, works brililantly at removing scum and marks off interior vynils |
Author: | carter [ Fri Feb 20, 2009 1:52 pm ] |
try thinners it seems to work well. |
Author: | Morris 1100 [ Fri Feb 20, 2009 4:11 pm ] |
Soap and water. You are trying to remove dirt, you are not trying to hurt the vinyl. Most trimmers recommended using soap and water. A scrubbing brush will help as long as it is not too rough, I use a nail brush but some people will use a toothbrush for the seams. Thinners, chemicals and a lot of other cleaning products will hurt the vinyl. |
Author: | Mini_Special [ Fri Feb 20, 2009 4:14 pm ] |
CRC So Easy Tire foam works quite well but makes it rather slippery. |
Author: | minidrifter [ Fri Feb 20, 2009 6:30 pm ] |
Do NOT use thinners as morris has said, it has a tendancy to 'split' the colours in the vinyl, effectively making them run. soap and water, or go to the local supercrap and get a hold of some of the meguiars, or armor all vinyl cleaner, talk to lachie (caponix), i got him to use the same stuff and should see his results ![]() ![]() |
Author: | Kyoda [ Fri Feb 20, 2009 7:18 pm ] |
Go to the supermarket and get some Gumption cleaner paste - in the household cleaning section. It works a treat. |
Author: | carter [ Fri Feb 20, 2009 7:46 pm ] |
ok maybe you shouldnt use thinners...... ![]() |
Author: | Blokeinamoke [ Fri Feb 20, 2009 7:50 pm ] |
sunlight soap and warm water |
Author: | michaelb [ Fri Feb 20, 2009 7:59 pm ] |
Spray and Wipe with a small scrubbing brush. Once dry then spray with Armorall to return some moisture into the vinyl. |
Author: | Morris 1100 [ Fri Feb 20, 2009 8:05 pm ] |
Nothing will return moisture to vinyl. ![]() It is a myth to sell expensive cleaning products. |
Author: | d1ck0 [ Fri Feb 20, 2009 8:23 pm ] |
.....and if you've worked in the motor trade for dealers and replaced as many dash tops as I have you wouldn't use Armourall on anything. |
Author: | Dylans Clubby [ Sun Feb 22, 2009 10:37 am ] |
thats interesting, i used amourall on my dash once, which then caused it o slowly warp... i think it started the process. on the subject, i was going to post a new thread but i'll just hijack instead (insert rude emoticon) how about cleaning seats with dot-cloth bits? i took my seat covers off the other day and my chairs are FILTHY!!! |
Author: | brett [ Sun Feb 22, 2009 3:39 pm ] |
Meguires doesnt leave the oily residue, just lifts the dirt off |
