Length? https://www.ausmini.com/forums/viewtopic.php?f=2&t=50488 |
Author: | Wombat [ Fri Feb 20, 2009 4:17 pm ] |
Post subject: | Length? |
I'm at work and they have tightened up the internet access even more - can't see pictures (they take up band width ![]() All I want to know is the length of the threaded rod for a DIY cone compressor |
Author: | Tombo [ Fri Feb 20, 2009 4:32 pm ] |
30 cm should be ample, withspare to cut off it the thread gets mashed. |
Author: | drmini in aust [ Fri Feb 20, 2009 6:11 pm ] |
You want good high tensile threaded rod and Grade 8 nuts, there are tons of force on this thing when done up. Put a plate on the crossmember or you will collapse it into the hole, there is no strength below it on these early subbies. |
