It is currently Mon Jul 21, 2025 9:09 am
PostPosted: Wed Feb 25, 2009 3:52 pm
Anyone used someone this side of town? Details and rough price would be great.
Aaron
PostPosted: Wed Feb 25, 2009 5:08 pm
The Mini King
The best Electroplater in Sydney Is Blu Chrome Electroplaters In Condell Park
However Try Artarmon Electroplaters ,Close To you
PostPosted: Wed Feb 25, 2009 6:29 pm
thanks john. will call tomorrow. kinda sick of all the dirty nuts bolts and brackets lying round here
PostPosted: Wed Feb 25, 2009 7:57 pm
Very timely! I have finally started to dismantle my 1275 LS and putting all the rusty, dirty, corroded nuts and bolts and brackets into a bucket so they can be degreased and sent off for replating. :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Feb 25, 2009 8:06 pm
The Mini King
I should have mentioned Blu Chrome Is Great for Chrome and Zinc plating, However If you are wanting nuts bolts washers etc plated These would be more expensive at Blu Chrome as They do Not do Barrel Plating, So all these would have to be wired up to plate them
PostPosted: Wed Feb 25, 2009 8:12 pm
Thanks John, I will try the place at Condell Park.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Feb 25, 2009 8:16 pm
Oops! :? Try again. I will try the other place.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Feb 25, 2009 8:50 pm
John, which one would you recommend for doing 850 grill? Thanks
1964 Morris Mini 850 - G13b gti powered - classic yet practical
1968 Morris Minimatic - 1100cc - classic & breakable
Sun Certified Java Programmer v5 310-055
PostPosted: Wed Feb 25, 2009 8:54 pm
....and approx cost to do same.. :wink:
PostPosted: Wed Feb 25, 2009 9:13 pm
For any one else, do not use Pine Rivers Electroplating in Brisbane. They have had parts of mine for over 6 months and were paid in full for the work 5 months ago....
PostPosted: Wed Feb 25, 2009 9:19 pm
The Mini King
As Some people on this Forum may know I am an electroplater,
The 850 grille is very hard to re plate and have it look as it did new, This is because to get the best chrome finish the metal has to be polished smooth before Plating, This is extremely hard to do in the recesses on the 850 grille, they are usually rusted in these places and as a result pitted, to remove these pit marks is a Lot of work and time, This equals a lot of dollars most Platers do not have the time or the inclination to remove these marks, So what you get is a grille that is very good on the flat surfaces but tends to look a little like silver frost in the recessed areas, Depending on how badly pitted it is to start with. I am happy to explain this in detail to anyone who wants to call me
02 46481233
PostPosted: Wed Feb 25, 2009 9:29 pm
Here's some motivation...
Zinc plating will be the Jesus stick on your parts however...if some are worn a little thin with age then they will come back with holes in them. Think carefully about your more uncommon stuff, like Cooper parts, tin brake cylinders etc. If they're a little marginal, think twice about putting them in.
You can see in the third photo that a lot of bolts have severe pitting, this is not the usual case when zinc plating. They were especially marginal as they came from some pretty rusty components and so were turfed to the very last last resort bucket.
PostPosted: Thu Feb 26, 2009 5:45 am
High heel ninja
Aaron
That reminds me mate, i better go pick our stuff up from the platers, my bad.
Doogie
Users browsing this forum: winabbey and 81 guests
