It is currently Sun Jul 20, 2025 11:33 pm
 Post subject: Replace or not?
PostPosted: Wed Feb 25, 2009 9:33 pm
The rear sub frame support pin that is.
One of mine has a strip of rust corrosion about 1mm deep right along the length of the shaft - not just surface but starting to eat below the surface. it's effecting the 'roundness' more than the strength integrity I would think but just wondering if it would be of concern.
This is the pin I mean
If you can imagine that strip of white as the rust that is about the size and shape
David L
PostPosted: Wed Feb 25, 2009 9:45 pm
Easily found I suppose... And it will only jam up when it rusts again...
PostPosted: Wed Feb 25, 2009 10:56 pm
Tomboss Breweros
Ah, just coat it in neversieze and put it together.
If you are worried, polish it. Removing surface im-perfections from a bit of metal makes it stronger.
kimini wrote:
Jimmyinamini wrote:
