It is currently Wed Jul 23, 2025 6:29 pm
 Post subject: weber leaking fuel?
PostPosted: Mon Feb 23, 2009 5:46 pm
My 45DCOE seems to be leaking fuel. The underside of the carb is damp with fuel after about 10 minutes of running at the slalom last week. Obviously i am not happy with a leaky carb sitting over a hot exhaust.
It has had a kit put in with all new gaskets and o-rings, but the bottom gasket in the kit did not fit as it was entirely the wrong shape. I cut a bit of gasket card to suit and installed that instead.
Just wondering if there are any "typical" reasons for this, like maybe float level set to high?
michael
PostPosted: Mon Feb 23, 2009 6:02 pm
I is a mookenik
this sounds to familar.... i think every weber leaks. they become loose and also its a common problem.
PostPosted: Mon Feb 23, 2009 6:32 pm
mine leaked not soon after a rebuild....nothing to bad...
if its not gushing....i just left it alone...
PostPosted: Mon Feb 23, 2009 8:31 pm
I'm Bert , where's Ernie
mine does exactly the same thing, when i took it to gr about some other issues i asked him about it, he said i had two gaskets on it, so he told me to take one off, and also tighten up all the mounting nuts. simple, and it fixed it.
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Mon Feb 23, 2009 8:35 pm
They do tend to drip fuel from the softmount O-rings as said. I run a 45 Dellorto, they doesn't need the soft mounts, = no leaks. :D
PostPosted: Mon Feb 23, 2009 8:49 pm
High heel ninja
Mick, does it leak when its running? or just when its turned off? My Cooper S does the same, GR had a look and said its normal, she'll be right.
Doogie
PostPosted: Mon Feb 23, 2009 9:39 pm
Mine was dripping fuel after you turned off the engine. Not a huge amount, just a drip every 5 or so seconds.
I bought a new Redline soft mount kit from the local Dynotune for $25 and all is good now.
You can get the same kit from ebay for around $20 including post.
PostPosted: Tue Feb 24, 2009 3:55 am
Doogie
Not sure. When it is off and the fuel pump is running there does not appear to be a gushing leak.
I just want to know where to start looking.....
PostPosted: Tue Feb 24, 2009 3:56 am
soft mounts are new as well....
PostPosted: Tue Feb 24, 2009 9:02 am
Hey Mike I bet it's that bottom gasket you're talking about. My dellorto does not leak.
PostPosted: Tue Feb 24, 2009 5:57 pm
yeah i am going to pull it off the car and have a closer look. I don't care what people think is "normal", but a carby leaking fuel under any circumstances is not it.
michael
PostPosted: Tue Feb 24, 2009 8:41 pm
I have always wondered why there are so many fire extinguishers in minis. I think I am closer to why, webers.
PostPosted: Tue Feb 24, 2009 9:48 pm
You're more likely to start a fire from Lucas electrics than petrol... If petrol ignited anywhere along the fuel line, an extinguisher won't help you one bit
PostPosted: Wed Feb 25, 2009 4:00 am
which is why eliminating the leaks is a much better idea :shock:
 Post subject: Re: weber leaking fuel?
PostPosted: Wed Feb 25, 2009 8:15 am
Yeah a nice [pssst] of fuel over the exhaust isn't great safety-wise. I had this problem with my 45 DCOE. Turns out the centre plate on the air filter side wasn't fixed properly. I got her re-kitted and cleaned out now it doesn't drip at all. I'm using a one-piece redline soft-mount.
I've got a weber air box so it was showing a yellow/black colour which is how I noticed it.
