weber leaking fuel?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=50561
Page 1 of 2
Author:  mickmini [ Mon Feb 23, 2009 5:46 pm ]
Post subject:  weber leaking fuel?
My 45DCOE seems to be leaking fuel. The underside of the carb is damp with fuel after about 10 minutes of running at the slalom last week. Obviously i am not happy with a leaky carb sitting over a hot exhaust.
It has had a kit put in with all new gaskets and o-rings, but the bottom gasket in the kit did not fit as it was entirely the wrong shape. I cut a bit of gasket card to suit and installed that instead.
Just wondering if there are any "typical" reasons for this, like maybe float level set to high?
michael
Author:  tinymorris1969 [ Mon Feb 23, 2009 6:02 pm ]
this sounds to familar.... i think every weber leaks. they become loose and also its a common problem.
Author:  minifreak1 [ Mon Feb 23, 2009 6:32 pm ]
mine leaked not soon after a rebuild....nothing to bad...
if its not gushing....i just left it alone...
Author:  minidrifter [ Mon Feb 23, 2009 8:31 pm ]
mine does exactly the same thing, when i took it to gr about some other issues i asked him about it, he said i had two gaskets on it, so he told me to take one off, and also tighten up all the mounting nuts. simple, and it fixed it.
Author:  drmini in aust [ Mon Feb 23, 2009 8:35 pm ]
They do tend to drip fuel from the softmount O-rings as said. I run a 45 Dellorto, they doesn't need the soft mounts, = no leaks. :D
Author:  doogie [ Mon Feb 23, 2009 8:49 pm ]
Mick, does it leak when its running? or just when its turned off? My Cooper S does the same, GR had a look and said its normal, she'll be right.
Doogie
Author:  Austin850 [ Mon Feb 23, 2009 9:39 pm ]
Mine was dripping fuel after you turned off the engine. Not a huge amount, just a drip every 5 or so seconds.
I bought a new Redline soft mount kit from the local Dynotune for $25 and all is good now.
You can get the same kit from ebay for around $20 including post.
Author:  mickmini [ Tue Feb 24, 2009 3:55 am ]
Doogie
Not sure. When it is off and the fuel pump is running there does not appear to be a gushing leak.
I just want to know where to start looking.....
Author:  mickmini [ Tue Feb 24, 2009 3:56 am ]
soft mounts are new as well....
Author:  Lillee [ Tue Feb 24, 2009 9:02 am ]
Hey Mike I bet it's that bottom gasket you're talking about. My dellorto does not leak.
Author:  mickmini [ Tue Feb 24, 2009 5:57 pm ]
yeah i am going to pull it off the car and have a closer look. I don't care what people think is "normal", but a carby leaking fuel under any circumstances is not it.
michael
Author:  bamnfi [ Tue Feb 24, 2009 8:41 pm ]
I have always wondered why there are so many fire extinguishers in minis. I think I am closer to why, webers.
Author:  Lillee [ Tue Feb 24, 2009 9:48 pm ]
You're more likely to start a fire from Lucas electrics than petrol... If petrol ignited anywhere along the fuel line, an extinguisher won't help you one bit
Author:  mickmini [ Wed Feb 25, 2009 4:00 am ]
which is why eliminating the leaks is a much better idea :shock:
Author:  smiling_simon [ Wed Feb 25, 2009 8:15 am ]
Post subject:  Re: weber leaking fuel?
Yeah a nice [pssst] of fuel over the exhaust isn't great safety-wise. I had this problem with my 45 DCOE. Turns out the centre plate on the air filter side wasn't fixed properly. I got her re-kitted and cleaned out now it doesn't drip at all. I'm using a one-piece redline soft-mount.
I've got a weber air box so it was showing a yellow/black colour which is how I noticed it.
