Replace or not? https://www.ausmini.com/forums/viewtopic.php?f=2&t=50646 |
Author: | Wombat [ Wed Feb 25, 2009 9:33 pm ] |
Post subject: | Replace or not? |
The rear sub frame support pin that is. One of mine has a strip of rust corrosion about 1mm deep right along the length of the shaft - not just surface but starting to eat below the surface. it's effecting the 'roundness' more than the strength integrity I would think but just wondering if it would be of concern. This is the pin I mean ![]() If you can imagine that strip of white as the rust that is about the size and shape |
Author: | Mick [ Wed Feb 25, 2009 9:45 pm ] |
Easily found I suppose... And it will only jam up when it rusts again... |
Author: | Tombo [ Wed Feb 25, 2009 10:56 pm ] |
Ah, just coat it in neversieze and put it together. If you are worried, polish it. Removing surface im-perfections from a bit of metal makes it stronger. |
