waterpump
https://www.ausmini.com/forums/viewtopic.php?f=2&t=50677
Page 1 of 2
Author:  Leighton [ Thu Feb 26, 2009 8:33 pm ]
Post subject:  waterpump
which water pump should i use? a high flow or just a standard one?
ive got a 1060 Re13 cam, head work (de-shrouded valves), skimmed dont know exact i think GR said 100-200thou off, GR's high comp pistons.
cheers leighton
Author:  1310/71 [ Thu Feb 26, 2009 8:40 pm ]
I think the hi-flow is in order, but equally important to make sure your whole cooling system is in shape too eg radiator, fan etc.
Author:  Leighton [ Thu Feb 26, 2009 8:48 pm ]
yep ill make sure its all good.
what type of needle for a 1 and 1/2" SU on a standard manifold would i need?
cheers leighton
Author:  Gadgets mini [ Thu Feb 26, 2009 9:20 pm ]
try a water pump that doesn't look like this :wink: :wink:
Author:  Leighton [ Thu Feb 26, 2009 9:32 pm ]
yer thats pretty much my old one
Author:  Gadgets mini [ Thu Feb 26, 2009 9:36 pm ]
I went the high flow
it handled the recent heat wave with no problems :wink:
Author:  Leighton [ Thu Feb 26, 2009 9:38 pm ]
k thanks
Author:  simon k [ Thu Feb 26, 2009 9:50 pm ]
dunno why anyone would by the standard one....
Author:  Leighton [ Thu Feb 26, 2009 10:13 pm ]
because they're uneducated like me :D
Author:  850man [ Thu Feb 26, 2009 10:13 pm ]
Buy a pump with a cast iron impeller, not the cheap S@%! pressed steel type. I have only used std pumps on every motor i have ever built including all my race motors and have never had the need for a "high flow" pump.
Author:  drmini in aust [ Fri Feb 27, 2009 7:28 am ]
Stay away from the ones with bent tin impellers, they are rubbish.
If putting a hi-flow one in a smallbore, check the impeller doesn't foul inside the block...
Author:  justminis [ Fri Feb 27, 2009 7:29 am ]
For the purposes of discussion and leaving the pressed steel impeller type alone, what is the difference between a standard water pump and a "high flow" pump?
Author:  drmini in aust [ Fri Feb 27, 2009 7:49 am ]
High flow impeller is wider, by maybe 1/4". :wink:
Author:  mattsmadmini [ Fri Feb 27, 2009 9:10 am ]
Yeh made that rookie error last year.... standard pump should be up to the job if the rest of the cooling system is in good nick...
Author:  Wombat [ Fri Feb 27, 2009 11:25 am ]
And if it does....?
