13secmini wrote:
i think you have to reclibrate the speedo,, to do this they need to get to the back of the dash and change the gear the cable goes into,,, need to do mine too
What he said......yes it ain't rocket science...the cable comes out of the gearbox and drives a big spiral of a gear in the speedo...
you can fiddle in there CAREFULLY or you can get a little conversion box do-hickey that connects out of the gearbox....if it is not wildly inaccurate...why not just take it to a measured Kilometre and determine where it is really reading with a stop watch or GPS...note the Tacho reading (if fitted) and you have two points where you can check your speed (you obviously need to do the check at maybe 60 and 100 clicks).
Alternatively, suss out the correct gears for that model and look for a whole instrument or just the gears.
