running rough - stupid question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=50743
Author:  woodwormm [ Sun Mar 01, 2009 10:44 am ]
Post subject:  running rough - stupid question
I hate asking questions like this.....
anyone got a picture of which plug lead goes where?
Author:  Tombo [ Sun Mar 01, 2009 10:53 am ]
Often mini distributors have been put in at different angles. My reccomended trick is this, take out no. 1 plug and get someone to crank the key a tiny bit at a time while you have your finger over the hole (it won't hurt you), when air pushes out stop, ignition off, into 4th and look in the hole while slowly moving the car forward. when the piston is at the top the rotor will be pointing to no 1 lead. Then the firing order anti clockwise is 1-3-4-2.
Author:  DTrain [ Sun Mar 01, 2009 3:52 pm ]
1 - 3 - 4 - 2 anti-clockwise
a car wont start with the leads being on the wrong way, but if it does then it will sound like shite, and you will know.
explain what you mean by running rough - at idle, through the rev range etc could be your timing, points, carb, air leak, pretty much anything making it run rough.
Author:  Mick [ Sun Mar 01, 2009 4:20 pm ]
The pic above shows the order anti clockwise of 1-3-4-2, but a previous owner may have put the distributor in out of normal alignment to the above.
If it still does not work at all, rotate the leads anti clockwise until it does fire.
Once it's done, get a timing light and check your timing is still correct or you will risk further problems.
Author:  woodwormm [ Sun Mar 01, 2009 7:53 pm ]
thanks everyone,
i just fouled the plugs the other day. pulled em and cleaned em, large weekend and i forgot where the leads came from..... just goes to show the mini shouldn't be worked on with a hangover...!
cheers.
Author:  Morris 1100 [ Sun Mar 01, 2009 8:59 pm ]
woodwormm wrote:
thanks everyone,
cheers.
You should mark the leads to tell you next time...
Look at the number of cable ties on each lead...
Author:  YoungMiniac [ Sun Mar 01, 2009 9:23 pm ]
What a great idea, have to remember that one :)
Author:  sgc [ Sun Mar 01, 2009 9:40 pm ]
Just be sure to remember which is #1 ;)
Author:  Boyracer [ Sun Mar 01, 2009 10:10 pm ]
It's no problem with a hangover, you just do things a little slower. I'd just pull one lead at a time, believe me I never get mixed up doing it this way.
