It is currently Thu Aug 21, 2025 9:38 pm
 Post subject: balljoints.
PostPosted: Mon Mar 02, 2009 7:49 pm
I is a mookenik
i was nearly finished when i did the most stupidest thing, i hit the stud of the bolt by accident with a hammer while trying to get the thing off, now i have flattend the thread on the stud....
just want to know can i remove the ball joint and replace it or new hub?
PostPosted: Mon Mar 02, 2009 7:52 pm
Grind the nut back down it... she'll be right :lol:
PostPosted: Mon Mar 02, 2009 7:53 pm
read your MSN dude. :wink:
PostPosted: Mon Mar 02, 2009 7:56 pm
The "stud" is part of the ball joint, which you can replace. I would try finding a die nut for it and try to repair the thread, unless you REALLY messed it up. No need for a new hub.
Just need to bend the locktab down, and get a 1.5inch socket/spanner to fit the ball joint and you can replace it. You will need to set up the shims etc though.
PostPosted: Mon Mar 02, 2009 8:23 pm
use a thread file or get a die nut its easy to do. you should of learned this stuff at tafe
PostPosted: Mon Mar 02, 2009 8:50 pm
next time wind the nut out just past the thread of the ball joint and then hit it (whilst supporting the top or bottom arm). if i remember correctly, removing the bottom one first was the easier way.
PostPosted: Mon Mar 02, 2009 8:54 pm
This space for rent
Joe, go buy a balljoint splitter and leave the BFH on the bench....
PostPosted: Mon Mar 02, 2009 10:54 pm
I is a mookenik
its ok problem solved, went and borrows a thread file from a mate and fixed the thread..good as new.
PostPosted: Tue Mar 03, 2009 6:45 am
I was going to suggest getting a mechanic to help you.
(before BIAM or Hanra got there first). :D
KB
Users browsing this forum: No registered users and 211 guests
