balljoints.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=50812
Author:  tinymorris1969 [ Mon Mar 02, 2009 7:49 pm ]
Post subject:  balljoints.
i was nearly finished when i did the most stupidest thing, i hit the stud of the bolt by accident with a hammer while trying to get the thing off, now i have flattend the thread on the stud....
just want to know can i remove the ball joint and replace it or new hub?
Author:  willy [ Mon Mar 02, 2009 7:52 pm ]
Grind the nut back down it... she'll be right :lol:
Author:  drmini in aust [ Mon Mar 02, 2009 7:53 pm ]
read your MSN dude. :wink:
Author:  mini_mad_matt [ Mon Mar 02, 2009 7:56 pm ]
The "stud" is part of the ball joint, which you can replace. I would try finding a die nut for it and try to repair the thread, unless you REALLY messed it up. No need for a new hub.
Just need to bend the locktab down, and get a 1.5inch socket/spanner to fit the ball joint and you can replace it. You will need to set up the shims etc though.
Author:  TUCK3r [ Mon Mar 02, 2009 8:23 pm ]
use a thread file or get a die nut its easy to do. you should of learned this stuff at tafe
Author:  DTrain [ Mon Mar 02, 2009 8:50 pm ]
next time wind the nut out just past the thread of the ball joint and then hit it (whilst supporting the top or bottom arm). if i remember correctly, removing the bottom one first was the easier way.
Author:  sgc [ Mon Mar 02, 2009 8:54 pm ]
Joe, go buy a balljoint splitter and leave the BFH on the bench....
Author:  tinymorris1969 [ Mon Mar 02, 2009 10:54 pm ]
its ok problem solved, went and borrows a thread file from a mate and fixed the thread..good as new.
Author:  1310/71 [ Tue Mar 03, 2009 6:45 am ]
I was going to suggest getting a mechanic to help you.
(before BIAM or Hanra got there first). :D
KB
