Stripped thread on hub https://www.ausmini.com/forums/viewtopic.php?f=2&t=50828 |
Author: | peterw [ Tue Mar 03, 2009 12:00 pm ] |
Post subject: | Stripped thread on hub |
I have a disc brake hub with a stripped thread where the bottom ball joint screws on. Anyone successfully repaired one like this? Pete |
Author: | drmini in aust [ Tue Mar 03, 2009 12:04 pm ] |
Toss it away, they are cast iron. NOT steel... ![]() |
Author: | tinymorris1969 [ Tue Mar 03, 2009 9:02 pm ] |
lol i repaired mine last nite ![]() |
Author: | sgc [ Tue Mar 03, 2009 9:08 pm ] |
tinymorris1969 wrote: lol i repaired mine last nite
![]() Not the balljoint pin Joe, the actual hub itself, where the big 1-1/2" inch nut screws down. Like Doc says, if that's stuffed the hub is stuffed... |
Author: | tinymorris1969 [ Tue Mar 03, 2009 9:10 pm ] |
ohhhh dam yep ur screwd... |
Author: | sports850 [ Tue Mar 03, 2009 9:10 pm ] |
Joe , two different things , you were talking about the end of the ball joint where the nut screws on weren't you ? Peter is talking about the thread on the hub where the ball joint cup screws onto . If the threads damaged on the hub the ball joint can seperate from the hub under load (read that as in a hard corner) and fold the wheel up under the guard so isn't worth fiddling with . |
Author: | tinymorris1969 [ Tue Mar 03, 2009 9:12 pm ] |
yeah i thought he was talking about the balljoint stud itself lol. |
Author: | peterw [ Tue Mar 03, 2009 10:25 pm ] |
I figured it was toast. Just thought I would ask in case someone smarter than me had found a way to fix one. Thanks for the confirmation. Pete |
