It is currently Wed Jul 30, 2025 12:35 pm
PostPosted: Thu Mar 05, 2009 6:41 pm
i've just put my rear end together on the mini to realised that the quadrants don't pivot on the the trailing arm , it worked before i pulled it apart. now its back together the quadrants don't want to pivot on the trailing arm does any one have a pic of how the quadrant should be set to get a free pivoting action.i looked in the mini king catalouge and says it has spaces when i pulled it apart there where no spaces just a washer and a spring washer.
Cheers TUCK3R
PostPosted: Thu Mar 05, 2009 8:27 pm
Are they binding on the arm or are the bushes within the arm damaged?
Have you put the quadrants in upside down?
PostPosted: Thu Mar 05, 2009 8:29 pm
They swing very freely - just tilting the arm and the quadrants find their own low point
PostPosted: Fri Mar 06, 2009 9:38 pm
thanks for the picture. i have the bolt going coming from the top. but that shouldnt make that much difference other than that i think i may have over tightened it?
Users browsing this forum: Bing [Bot], Hobson and 95 guests
