It is currently Tue Jul 22, 2025 7:33 pm
 Post subject: Put in an oil cooler?
PostPosted: Sun Mar 08, 2009 6:40 am
Hi all
body is still being restored & engine not rebuilt yet.
Someone mentioned to me to install an oil cooler.
Do I need an oil cooler?
Put one in what differences will I see?
Craig
(Edit) good for track but not necessary for daily driver?
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Sun Mar 08, 2009 7:44 am
cd wrote:
Hi all
Craig
With a good cooling system, good oil in its belly..why bother :?: (just another ancilliary that can cause problems or impede access)
If you are going for a particular look...then fill your boots :D
PostPosted: Sun Mar 08, 2009 8:14 am
I measured that it took 25 minutes to warm the oil up to running temperature in a warm 1330 with cooler in mild (neither hot nor cold) weather. This only dropped by five minutes if you went straight out on the freeway.
PostPosted: Sun Mar 08, 2009 8:49 am
Unless it's a track car I'd forget it. I took mine off last year. Oil pressure is still the same, except idle pressure after a freeway run is down a little for about 5 mins.
They do not make the engine run cooler.
In daily traffic, they do nothing....
PostPosted: Sun Mar 08, 2009 9:57 am
As the good Doc and Mick said .....not worth the hassle unless you are doing a concourse "S" or "GT". Just another storage place for old oil.
PostPosted: Sun Mar 08, 2009 12:39 pm
Thanks all for the replies.
I will not worry about it, as the good Doc says.
I can save that money & put it towards heaps of other stuff I need.
Craig
1927 Austin 7
Users browsing this forum: Gatti and 77 guests
