Put in an oil cooler? https://www.ausmini.com/forums/viewtopic.php?f=2&t=50974 |
Author: | cd [ Sun Mar 08, 2009 6:40 am ] |
Post subject: | Put in an oil cooler? |
Hi all body is still being restored & engine not rebuilt yet. Someone mentioned to me to install an oil cooler. Do I need an oil cooler? Put one in what differences will I see? Cheers Craig (Edit) good for track but not necessary for daily driver? |
Author: | 9YaTaH [ Sun Mar 08, 2009 7:44 am ] |
Post subject: | Re: Put in an oil cooler? |
cd wrote: Hi all
body is still being restored & engine not rebuilt yet. Someone mentioned to me to install an oil cooler. Do I need an oil cooler? Put one in what differences will I see? Cheers Craig (Edit) good for track but not necessary for daily driver? With a good cooling system, good oil in its belly..why bother ![]() If you are going for a particular look...then fill your boots ![]() |
Author: | Mick [ Sun Mar 08, 2009 8:14 am ] |
I measured that it took 25 minutes to warm the oil up to running temperature in a warm 1330 with cooler in mild (neither hot nor cold) weather. This only dropped by five minutes if you went straight out on the freeway. |
Author: | drmini in aust [ Sun Mar 08, 2009 8:49 am ] |
Unless it's a track car I'd forget it. I took mine off last year. Oil pressure is still the same, except idle pressure after a freeway run is down a little for about 5 mins. They do not make the engine run cooler. In daily traffic, they do nothing.... |
Author: | BALLISTIC [ Sun Mar 08, 2009 9:57 am ] |
As the good Doc and Mick said .....not worth the hassle unless you are doing a concourse "S" or "GT". Just another storage place for old oil. |
Author: | cd [ Sun Mar 08, 2009 12:39 pm ] |
Thanks all for the replies. I will not worry about it, as the good Doc says. I can save that money & put it towards heaps of other stuff I need. Cheers Craig |
