Cooper S rims? https://www.ausmini.com/forums/viewtopic.php?f=2&t=50987 |
Author: | bamnfi [ Sun Mar 08, 2009 3:27 pm ] |
Post subject: | Cooper S rims? |
Does anyone know where you can buy the alloy copies of the original Cooper style wheels? |
Author: | brett [ Sun Mar 08, 2009 8:57 pm ] |
http://www.minisport.com/acatalog/Mini_ ... heels.html these?? |
Author: | Mick [ Sun Mar 08, 2009 9:22 pm ] |
Well they're the steel wheel repros, but equally as noice... |
Author: | simon k [ Sun Mar 08, 2009 11:10 pm ] |
how much are you offering ![]() ![]() these are the ones you want - they're bloody cheap for what they are.. Kevin aka. Rehab1964 is planning (or has already ordered) some, I was tossing up getting a spare http://www.minisport.com/acatalog/info_SPDSR-011-S.html Mine came from Japan, but I'm 99% sure these are the same, though my wheels are slightly different in the valve stem recess. My wheels have a solid metal valve stem, a rubber stem wouldn't go in them without drilling the hole bigger |
Author: | Tombo [ Sun Mar 08, 2009 11:12 pm ] |
simon k wrote: Mine came from Japan, but I'm 99% sure these are the same, though my wheels are slightly different in the valve stem recess. My wheels have a solid metal valve stem, a rubber stem wouldn't go in them without drilling the hole bigger
They do look very good, i like ![]() |
Author: | simon k [ Sun Mar 08, 2009 11:14 pm ] |
Tombo wrote: simon k wrote: Mine came from Japan, but I'm 99% sure these are the same, though my wheels are slightly different in the valve stem recess. My wheels have a solid metal valve stem, a rubber stem wouldn't go in them without drilling the hole bigger They do look very good, i like ![]() and lighter than a contessa - somewhere under 2.5kg 10kg's from UK ought to be cheap |
Author: | Tombo [ Sun Mar 08, 2009 11:22 pm ] |
simon k wrote: and lighter than a contessa - somewhere under 2.5kg 10kg's from UK ought to be cheap <hijack> are you suggesting my wheels are heavy and i have added unnececary weight? ![]() ![]() |
Author: | bamnfi [ Mon Mar 09, 2009 8:34 am ] |
simon k wrote: how much are you offering
![]() ![]() these are the ones you want - they're bloody cheap for what they are.. Kevin aka. Rehab1964 is planning (or has already ordered) some, I was tossing up getting a spare http://www.minisport.com/acatalog/info_SPDSR-011-S.html Mine came from Japan, but I'm 99% sure these are the same, though my wheels are slightly different in the valve stem recess. My wheels have a solid metal valve stem, a rubber stem wouldn't go in them without drilling the hole bigger Yep, I found them esterday before I posted. Being an optimist I was hoping there maybe some closer that the UK. Bummer. Thanks anyway folks. |
Author: | simon k [ Mon Mar 09, 2009 11:53 am ] |
bamnfi wrote: simon k wrote: how much are you offering ![]() ![]() these are the ones you want - they're bloody cheap for what they are.. Kevin aka. Rehab1964 is planning (or has already ordered) some, I was tossing up getting a spare http://www.minisport.com/acatalog/info_SPDSR-011-S.html Mine came from Japan, but I'm 99% sure these are the same, though my wheels are slightly different in the valve stem recess. My wheels have a solid metal valve stem, a rubber stem wouldn't go in them without drilling the hole bigger Yep, I found them esterday before I posted. Being an optimist I was hoping there maybe some closer that the UK. Bummer. Thanks anyway folks. well, mine are closer, if you pay me more than it'll cost me to land another set sent out from UK, then I'll sell ![]() teaser photo: and yes Tom, you've got unnecessary weight, I suppose you're running cast iron brake drums too - sheesh ![]() |
Author: | bamnfi [ Mon Mar 09, 2009 12:18 pm ] |
Simon, such a generous offer! Somehow I will pass on the largesse. Now I'll be a real dill and see how much it woulda cost you to get them in ![]() |
