Finally finished installing the new wiring loom today (only taken about 7 years
)- mainly the rear section - so far only the lights each end are hooked up but at least the actual loom is in.
Must be getting short term memory loss as after checking the new loom lined up with the old in the boot I pull the old one out through the corner of the parcel shelf into cabin then promtly forgot how it ran into the boot - does it run down the back of the petrol tank or over the top of the tank?
David L
