The indicator flasher light on the stork is constantly on? https://www.ausmini.com/forums/viewtopic.php?f=2&t=51035 |
Author: | Brad's 68 [ Tue Mar 10, 2009 7:44 am ] |
Post subject: | The indicator flasher light on the stork is constantly on? |
Hi, I was hoping someone could advise on what this might be? the indicator flasher light on the stork is constantly on? Its not flashing. This has only just happened but was flashing very slow before it became permanently on? ![]() Thanks, |
Author: | Wombat [ Tue Mar 10, 2009 8:50 am ] |
Stuffed - needs a new flasher can |
Author: | bamnfi [ Tue Mar 10, 2009 10:07 am ] |
Brad, you're lucky, mine doesn't work at all. |
Author: | Flute [ Tue Mar 10, 2009 11:04 am ] |
One of the wires may have come out. If yours is the same as mine there are five wires coming from the steering wheel and there is a connector under the dash where they join the loom. Check that none of the wires are loose there or pull them out one by one (careful not to short live wires) to see when it goes off and then trace that wire back to see what the problem is. May be a short under the column shroud too but will make it easier when you know which colour wire to look for. I am no expert but have been having trouble getting a new stalk to work so have been fiddling with these wires for a while. Failing all that an auto elec could probably fix it straight away. Hope this helps... a bit! |
