Dyno Day new Needle https://www.ausmini.com/forums/viewtopic.php?f=2&t=5111 |
Page 1 of 2 |
Author: | gafmo [ Sun Feb 27, 2005 7:48 am ] |
Post subject: | Dyno Day new Needle |
Okay I did the Dyno Day yesturday and we got 45.2..But its running rich low down and lean up top....Bugger ay but atleast I know I have tried WinSU152 but they dont have out 1098 +20/40/60 and of course they dont have the RE13 cam...I know the cam is close to .290 but which manifacture should I use for winsu Otherwise anyone in the know..what needle should I use....1098 +60 RE13 (290) cam a little shaved off the head LCB (perry) HIF44 Needle EDP I need Leaner down low and and richer up top |
Author: | Circus_Maximus [ Sun Feb 27, 2005 11:23 am ] |
G'Day Gafmo, You will need to pull the needle out from your carby and get the code number stamped on it. I have the SU needle book with all the profiles and code numbers, but I have found that these days, not that many of them are available. Alternative would be to machine your own or modify an existing one. Dino |
Author: | poeee [ Sun Feb 27, 2005 11:53 am ] |
Are you sure it's an EDP needle? It's not on the list in winSU |
Author: | gafmo [ Sun Feb 27, 2005 8:51 pm ] |
poeee wrote: Are you sure it's an EDP needle? It's not on the list in winSU
Funny you sould say that Scott...I also tried WinSU152 first proir to asking starting this thread.. ![]() ![]() I have also ask this question in another forum ![]() ![]() ![]() I just cant see how it can wear in thier ![]() I'll recheck and refer ![]() Cheers Guys |
Author: | min13k [ Sun Feb 27, 2005 11:48 pm ] |
i think my 44 had a bbz in it hey phildo what needle was in the carby ?? makka |
Author: | drmini in aust [ Mon Feb 28, 2005 5:58 am ] |
OK I'll hijack this thread right here.. ![]() what needles should I run in Barney- twin HS4s on a 1293, with Ramflo filters & an RE-13 (similar to 276/286) cam? ![]() Any ideas? It's been 35 years since I ran twin HS4s... ![]() /end hijack... ![]() |
Author: | Boostedmini [ Mon Feb 28, 2005 10:05 am ] |
Hi Kev, check with chris because the twin HS4's i sold him were off dads old 1293 "S" but i cant remember what they were, he may remember the codes. |
Author: | min13k [ Mon Feb 28, 2005 11:54 am ] |
1 1/4 run bdl's if that is any help ![]() makka |
Author: | 9YaTaH [ Mon Feb 28, 2005 12:08 pm ] |
Post subject: | Vizard |
drmini in aust wrote: OK I'll hijack this thread right here..
![]() what needles should I run in Barney- twin HS4s on a 1293, with Ramflo filters & an RE-13 (similar to 276/286) cam? ![]() Any ideas? It's been 35 years since I ran twin HS4s... ![]() /end hijack... ![]() Step 1...consult Vizard??...to get you in the ballpark Step 2....dyno to optimise.. Step 3....road test to confirm dyno outcome??? ![]() |
Author: | drmini in aust [ Mon Feb 28, 2005 8:17 pm ] |
Yeah Vizard sez RED springs, with #3 or #4 needles... ![]() I think step 3 comes before step 2, Mick.. unless you work for lotsa $$$, which I don't.. ![]() OTOH the dyno guy might have a tin full of needles to try, and only charge me for the last pair.. ![]() |
Author: | 9YaTaH [ Mon Feb 28, 2005 10:07 pm ] |
Post subject: | Ouch |
drmini in aust wrote: Yeah Vizard sez RED springs, with #3 or #4 needles...
![]() I think step 3 comes before step 2, Mick.. unless you work for lotsa $$$, which I don't.. ![]() OTOH the dyno guy might have a tin full of needles to try, and only charge me for the last pair.. ![]() Well if they come that caper they probably aint too Mini friendly and you should get outta there ![]() Hmmmmm, lots of road testing without the benefit of a sensor up its clacker etc etc ...just my 5c ![]() |
Author: | drmini in aust [ Mon Feb 28, 2005 10:12 pm ] |
![]() ![]() I'm just intimidated by the cost of needles, x2, and the selection of 800? to choose from. ![]() And people wonder why I prefer tuning Dellortos etc.. ![]() |
Author: | willy [ Mon Feb 28, 2005 10:14 pm ] |
Yeah SU's are bastards of things. Once you get the right needle, then set them up just right, you have to do it again in a month coz its gone out of adjustments! SU carbs and Mini drum brakes - the two worst things the English have come out with ![]() |
Author: | Lillee [ Mon Feb 28, 2005 10:30 pm ] |
Oi! Don't knock the drum brakes! ![]() ![]() |
Author: | Circus_Maximus [ Tue Mar 01, 2005 11:11 am ] |
G'Day, Don't know what you guy's are going on about SU carby's... I had my twin SU's properly re-built and GR set up the needles while running in the engine on his dyno, have not touched them in 5 years except to top up the oil, and clean the filters. With working chokes, mine start first kick summer or winter... Dino |
