Distributor housing question https://www.ausmini.com/forums/viewtopic.php?f=2&t=51115 |
Author: | Wombat [ Wed Mar 11, 2009 8:47 pm ] |
Post subject: | Distributor housing question |
Is there a gasket under the top flange between the flange and the block? |
Author: | Lillee [ Wed Mar 11, 2009 8:51 pm ] |
Memory stretch... there is a rubber O ring I think that sits on the spine of the dissy but I could be wrong |
Author: | Mick [ Wed Mar 11, 2009 8:52 pm ] |
There is an o-ring, but it is further down the shaft. It negates the need for a gasket on your distributor. |
Author: | Wombat [ Wed Mar 11, 2009 9:24 pm ] |
There is the housing the goes into the block and the distributor shaft goes down the middle of - There is an O ring on the shaft that should stop oil coming up the shaft but what about between the housing and the block? The previous owner smothered this area in gasket goo obviously to stop oil leaking but there doesn't seem to be any gasket |
Author: | Mick [ Wed Mar 11, 2009 9:35 pm ] |
No gasket required. You do see that oil works it's way up the shaft, but it doesn't cause any leaks. |
Author: | sitnlo62 [ Wed Mar 11, 2009 9:43 pm ] |
Is this what you are asking about David? Definately fitted with an "O" ring! ![]() Dave |
Author: | albino235 [ Wed Mar 11, 2009 9:49 pm ] |
sitnlo62 wrote: Is this what you are asking about David?
Definately fitted with an "O" ring! ![]() Dave Wow that looks pristine, how do you get things looking that clean and unworn? Or is it a new part ![]() |
Author: | sitnlo62 [ Wed Mar 11, 2009 10:00 pm ] |
albino235 wrote: sitnlo62 wrote: Is this what you are asking about David? Definately fitted with an "O" ring! Wow that looks pristine, how do you get things looking that clean and unworn? Or is it a new part ![]() No not a new part, just the attention to detail I put into building my engines. Dave |
Author: | Wombat [ Wed Mar 11, 2009 10:13 pm ] |
Thats what I mean - mine doesn't have any grooves in the body part but there is a grove at the top - Thanks now I'll look for an O ring to fit ![]() |
Author: | sitnlo62 [ Wed Mar 11, 2009 10:18 pm ] |
If yours dosen't have that groove maybe it is an early one. If you want one with a groove contact me and i will give you one. Dave |
Author: | Wombat [ Wed Mar 11, 2009 10:23 pm ] |
It is an early one - does the O ring sit in the middle rather than the top? |
Author: | sitnlo62 [ Wed Mar 11, 2009 10:32 pm ] |
The "O" ring goes in the "O" ring groove in the center of the machined section! Not at the top...... Dave |
Author: | Wombat [ Wed Mar 11, 2009 10:58 pm ] |
Just double checked - definately no groove - pulled another out of another bare block I have here and guess what? - groove with O ring ![]() |
Author: | Lillee [ Thu Mar 12, 2009 8:21 am ] |
Yay I was almost right |
