It is currently Mon Aug 18, 2025 8:37 pm
 Post subject: Rocker Options
PostPosted: Thu Mar 12, 2009 9:52 pm
What options are out there for Rockers these days? I think i priced some Yella Terra ones like 10yrs ago and they were about a grand. I was never able to get the cam specs out of GR back in 1999, but he had my cyl head and cam at the same time. So im not sue what would be suitable.
PostPosted: Thu Mar 12, 2009 10:47 pm
What are you trying to achieve Brad? Going to 1.5 rockers will only give an advantage in the upper rev ranges, typically revs not used around town. 1.5's also need setting up by checking overall lift at the valve to make sure there is sufficient clearance between the retainer and the valve guide seal and that the valve springs won't bind.
My order of preference of 1.5's would be - MiniSpares Keith Dodd non-roller type, then MiniSpares bushed rollers.
Steve
PostPosted: Fri Mar 13, 2009 6:24 am
If you want something in between, I modify the standard pressed steel ones with my own .044" offset bushes.
This gives a ratio (tested with an RE13 cam) of 1.31:1.
Standard pressed steel rocker measured 1.21:1,
sintered rockers 1.18:1,
S forged rockers 1.16:1, with the same cam.
If the pressed steel rockers are the 1275 variety (oval pads) they give 1.35:1 when offset bushed. I did a set recently for Simon K.
The rockers are bored to clean up, the bushes are pressed into the rockers, then offset bored to size in the mill. This ensures they are all the same geometry.
The rocker pillars are bored and bushed to move the shaft back 1.6mm.
Shaft is a HD thick wall.
PM me if interested. :wink:
<edit> I can also do Corolla ones, they give 1.46:1 ratio tested as above. On these, the rocker pillar shaft holes are plugged and welded, then the holes bored 4.0mm back.
Last edited by drmini in aust on Fri Mar 13, 2009 7:17 am, edited 1 time in total.
PostPosted: Fri Mar 13, 2009 7:01 am
Not a lot really Steve, I guess Im just bored so I thought id generate another task.
Looks good Kev, Ill send you a PM today.
Users browsing this forum: No registered users and 321 guests
