rover switch panel.. in an older mini how do they fit. https://www.ausmini.com/forums/viewtopic.php?f=2&t=51170 |
Author: | NG [ Fri Mar 13, 2009 10:45 am ] |
Post subject: | rover switch panel.. in an older mini how do they fit. |
i have both crash covers. now just wondering how do they sit in? there is no holes for bolts so does it just glue in? bit of tape haha ![]() no really how do you put it in your old mini. thanks for your help guys. |
Author: | jbeenz [ Fri Mar 13, 2009 4:00 pm ] |
They have brackets that bolt to the choke and heater cables, and bring the whole panel out an inch or so, to sit in the paded lower dash rail. |
Author: | NG [ Fri Mar 13, 2009 6:47 pm ] |
where can i get these brackets? |
Author: | Drekkus [ Fri Mar 13, 2009 7:59 pm ] |
I have one in my car.There was a bit of stuffing around to get the bolts to line up in the original holes so I've only done one side so far.There should be a sort of bracket and bolt thingie where the heater and choke cables go through. If I remember rightly I ended up grounding out the existing bolt and replacing it with a slightly longer one. |
Author: | NG [ Fri Mar 13, 2009 8:08 pm ] |
ive got a rover heater.. im kinda lost i dont realy see any brackets. ive only got a choke cable no heater cable im going to buy one. |
