SU needle Spec Starting point
https://www.ausmini.com/forums/viewtopic.php?f=2&t=51174
Author:  aaron [ Fri Mar 13, 2009 1:46 pm ]
Post subject:  SU needle Spec Starting point
Sitting on a Big Stock 1275 with using a 1.5"SU What is a good Starting point needle?
Aaron
Author:  drmini in aust [ Fri Mar 13, 2009 1:55 pm ]
Std needle for an early 1275 Moke with stock airfilter setup was an AAG.
My Leyland Black Book doesn't cover the 1275LS, but it would be different and no good to you as it had all the emissions crap on. :lol:
Author:  miniron [ Fri Mar 13, 2009 2:33 pm ]
From Clubman Parts List
1275LS needle - ABB with pollution gear air pump etc
RonR
Author:  TheMiniMan [ Fri Mar 13, 2009 2:35 pm ]
Aaron,, , what type of carb,, swung needle ?(self centering) .... or fixed type?
& has there been any work done inside???, like cyl head port work, bgger valves, camshaft upgrade etc???,,, is there extractors fitted etc???
If it`s got a bit of work done to it & if it`s a fixed needle type carb, i would try maybe BQ,,, probably a bit rich but shoud ge you started.
Author:  aaron [ Fri Mar 13, 2009 3:09 pm ]
Typo, It was supposed to say Bog Stock.
Matt Swung type.
Nothing done to it at all.
It has an ADE in at the moment but it is no where near right.... Idles great, Runs Poo....
I have only limited needles and was thinking about trying an M needle as i have one.
Anyone in Sydney have a bunch of needles? Mr Malure is off racing so he's no good to me tomorrow...
Author:  drmini in aust [ Fri Mar 13, 2009 4:46 pm ]
I have a bunch Aaron, but they are all fixed type. I reckon swing needles are poo. 8)
Author:  TheMiniMan [ Fri Mar 13, 2009 4:54 pm ]
I`s easy enough to change it over tho,,, in otherwords make a fixed needle fit into a swing type collar
Punch the old swing type needle out of the collar & then squeez the collar (just a tad mind you) & locktit the fixed type needle into the collar,,, hey presto, one swung type fixed needle
:-) I`ve done it heaps & heaps & heaps over the years & works a treat
especially if you don`t have the proper ""swung-to-fixed"" needle adaptor thingy, which is just basically a small hollow cyl of brass with a grub screw hole in it :-)
& if it`s stock, then maybe a dy or dz,,, again probly a tad rich for you but will certainly get you goig ok for sure
I don`t think an M will keep up tho
Author:  TheMiniMan [ Fri Mar 13, 2009 4:55 pm ]
Doc,,, you`d have a spare #6 wouldn`t you???,,, even that would be better than what he`s got
Author:  drmini in aust [ Fri Mar 13, 2009 4:59 pm ]
no #6 left but I have some CP4s (close)
Author:  TheMiniMan [ Fri Mar 13, 2009 5:33 pm ]
yeah,,, still a bit phat for him but will at least get him reving without coughing & spluttering
Author:  aaron [ Fri Mar 13, 2009 6:04 pm ]
Got it running ok, but would be best to swap the needle out. She's would right down on the seat....
Will Cha to kev on MSN and see if i can grab one of his CP4's
