It is currently Fri Jul 18, 2025 3:22 pm
PostPosted: Sat Mar 14, 2009 1:10 pm
Hi Guy,
The battery cable from front to rear (12V) wore through in a big way. Just wondering what sort of cable to use to replace it?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sat Mar 14, 2009 2:19 pm
Welding cable of the same diameter will be of higher quality & will carry the current without a worry.
Make sure you fit new grommets where it passes through the body (see the Adventures of BIAM for what happens if you don't)
PostPosted: Sat Mar 14, 2009 5:05 pm
Yep, and welding cable is flexible and has better insulation. It's much nicer to work with and your starter motor will probably spin a little better on cold mornings.
PostPosted: Sun Mar 15, 2009 3:36 pm
Thanks guys,
I ended up just going to repco and getting some cable. I went with a slightly larger diameter. It cranks so much better.
I did have a BIAM moment, hence having to replace it. It had rubbed through on the subframe. It was obviously worn through for quite some time, however yesterday whilst driving, I noticed that it was leaking smoke, so I pulled over and sure enough i couldn't see anything. But the car would not start again.
So I got it towed (thanks NRMA), and put it up on stands when I got home. I couldn't see anything on the cable, so decided to pull it out, and sure enough it had rubbed through quite badly.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Sun Mar 15, 2009 7:53 pm
Tomboss Breweros
ryan wrote:
I noticed that it was leaking smoke....
Yeah, smoke leaks usually mean something bad.
I think someone here has some genuine lucas smoke...
kimini wrote:
Jimmyinamini wrote:
