Battery Cable - Replacement
https://www.ausmini.com/forums/viewtopic.php?f=2&t=51205
Author:  ryan [ Sat Mar 14, 2009 1:10 pm ]
Post subject:  Battery Cable - Replacement
Hi Guy,
The battery cable from front to rear (12V) wore through in a big way. Just wondering what sort of cable to use to replace it?
Ryan
Author:  awdmoke [ Sat Mar 14, 2009 2:19 pm ]
Welding cable of the same diameter will be of higher quality & will carry the current without a worry.
Make sure you fit new grommets where it passes through the body (see the Adventures of BIAM for what happens if you don't)
Author:  Mick [ Sat Mar 14, 2009 5:05 pm ]
Yep, and welding cable is flexible and has better insulation. It's much nicer to work with and your starter motor will probably spin a little better on cold mornings.
Author:  ryan [ Sun Mar 15, 2009 3:36 pm ]
Thanks guys,
I ended up just going to repco and getting some cable. I went with a slightly larger diameter. It cranks so much better.
I did have a BIAM moment, hence having to replace it. It had rubbed through on the subframe. It was obviously worn through for quite some time, however yesterday whilst driving, I noticed that it was leaking smoke, so I pulled over and sure enough i couldn't see anything. But the car would not start again.
So I got it towed (thanks NRMA), and put it up on stands when I got home. I couldn't see anything on the cable, so decided to pull it out, and sure enough it had rubbed through quite badly.
Ryan
Author:  Tombo [ Sun Mar 15, 2009 7:53 pm ]
ryan wrote:
I noticed that it was leaking smoke....
Yeah, smoke leaks usually mean something bad.
I think someone here has some genuine lucas smoke...
