still overheating https://www.ausmini.com/forums/viewtopic.php?f=2&t=51228 |
Author: | micky [ Sun Mar 15, 2009 9:57 am ] |
Post subject: | still overheating |
well i have changed the thermostat and looked for leaks the radiator has been serviced 2 years ago should i re clean it. i have flushed it with radiator clean. the water is evaporating from somewhere any ideas ? its sitting on hot most of the time but sometimes doesnt and sits ok. |
Author: | niceboy1275 [ Sun Mar 15, 2009 1:02 pm ] |
reverse flush the radiator. Mine was doing that too, after the new thermostat as well, so I took the radiator out, flushed it both ways, with hot water and cold 4 times till the water ran clear, then put it back in, new hoses and clamps and a new radiator cap. Now shes runs normal even when flat out on a 40 degree day. Turns out my radiator cap was causing the main problem. For an extra 50 bucks spent on hoses, clamps and a cap, its still cheaper than breaking down on the side of the road. Good luck! |
