Plumbing? https://www.ausmini.com/forums/viewtopic.php?f=2&t=51238 |
Author: | Wombat [ Sun Mar 15, 2009 5:59 pm ] |
Post subject: | Plumbing? |
OK Have I got this right? Red booster to manifold Blue line hooking up the rest to manifold green lines - I don't know 1 where do I run the vac advance to and 2 what do I do with the nipple (with small hole) on side of air filter box? ![]() |
Author: | scotta_74 [ Sun Mar 15, 2009 6:10 pm ] |
Wombat, I think (Big I think) the nipple on the air filter box goes to the top of the rocker cover. The vac advance on the dizzy goes to the top of one of the SU carbs, there should be a little nipple between the dashpot and where the carb meets the manifold. This may also be covered with a black rubber stopper. Sorry im not much help on any of the others. |
Author: | drmini in aust [ Sun Mar 15, 2009 6:16 pm ] |
You have the pipes arse about, the valve sits on the manifold and the breather is the side entry. The rocker cover is sealed, S and 1100S have a filter in the cap. |
Author: | Wombat [ Sun Mar 15, 2009 7:19 pm ] |
scotta_74 wrote: The vac advance on the dizzy goes to the top of one of the SU carbs, there should be a little nipple between the dashpot and where the carb meets the manifold. No both blank - should of checked before I rebuilt them - I have two others with the little nipple on the side ![]() drmini in aust wrote: You have the pipes arse about, the valve sits on the manifold and the breather is the side entry.
The rocker cover is sealed, S and 1100S have a filter in the cap. OK I can fix the valve - wasn't thinking ![]() |
Author: | ryan [ Sun Mar 15, 2009 7:28 pm ] |
I fairly sure that the rocker cover is the wrong type. I think you should have the type with out the breather. Then you just need a oil cap with the breather in it. Ryan |
Author: | drmini in aust [ Sun Mar 15, 2009 8:17 pm ] |
Just block yours off... ![]() |
Author: | Wombat [ Sun Mar 15, 2009 8:24 pm ] |
drmini in aust wrote: Just block yours off...
![]() Or buy a bling ali cover? |
Author: | drmini in aust [ Sun Mar 15, 2009 8:31 pm ] |
Plug & chrome it. ![]() |
