It is currently Fri Aug 01, 2025 1:33 am
PostPosted: Wed Apr 01, 2009 8:22 pm
Hi Guys,
does this look like a Mini 850 floor Mat or Morris 1100 Mat?
Dave
PostPosted: Wed Apr 01, 2009 8:24 pm
I vote 850 , morris 1100 looked bigger and were ribbed from memory .
PostPosted: Wed Apr 01, 2009 8:25 pm
It is not Morris 1100 no matter what he claims on ebay.
PostPosted: Wed Apr 01, 2009 8:27 pm
New old stock Mini 850 then?
Dave
PostPosted: Wed Apr 01, 2009 8:31 pm
Get him to show more photo's if you can , it's missing the floor starter hole and the light dipper switch hole . Don't think the 850 had the embossed heel area either but could be wrong . It does look similar to the mats I got from the Mini King that were from a left hand drive UK mini 850 of some form , it has a super short pile carpet on the top when it's in a left hand drive car but a reasonably original looking rubber backing with the holes mostly in the right place when it's fitted upside down to a right hand drive mini . It didn't have the floor start button or the dipper switch hole either ....
PostPosted: Wed Apr 01, 2009 8:41 pm
Here's a photo of an original floor mat in an 850, shows the embossed heal pad, Yes?
Dave
PostPosted: Wed Apr 01, 2009 8:55 pm
Yep , I'll agree with that . My front mat was reduced to half a dozen bits and the drivers foot area was a missing piece so wasn't sure . Seen one without that I thought could have been a repro but couldn't prove it one way or another .
PostPosted: Wed Apr 01, 2009 9:16 pm
Thanks for your input Ian,
I guess I will see when it gets here,
For the money I thought it was worth the risk,
He did say it was 40 year old new old stock, but on the other hand said it was from a morris 1100 so we'll see!
Either way it won't break the bank :)
Dave
PostPosted: Wed Apr 01, 2009 9:17 pm
Good to hear , can you please put some photo's up in here when you get it ?
PostPosted: Wed Apr 01, 2009 9:21 pm
Dave
It can't be for a Morris 1100 for two good reasons...
Reason 1) If it was for a Morris 1100 I would have outbid you.
Reason 2) The gearstick hole is in the wrong spot. He said that the 1100 auto had the hole in a different spot to the manual but he is wrong. It is in the same spot and the cable runs under the floor.
PostPosted: Wed Apr 01, 2009 9:25 pm
Thanks for your input too Morris100,
Lets hope it is a mini one.
If I thought it was for 1100 I would have not bid so you would have had it for the $80....
Dave
PostPosted: Wed Apr 01, 2009 9:41 pm
Sure thing Ian, not a problem.
Dave
PostPosted: Wed Apr 01, 2009 10:08 pm
It's for an 850 cause it's got a bump for the push button floor start
David L
PostPosted: Thu Apr 02, 2009 8:19 am
Resident Haemorrhoid
My Morris 1100 floor mat looks different
it also whines alot when i rub my feet on it, it also takes off to the pub every now and then :wink: :lol: :lol:
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Apr 02, 2009 8:25 am
It could be for a Mini autoMatic, they used the 850 shifter hole for the cable, and no floor starter.
Wombat, all Oz (& UK Mk1 & II) Minis have the starter bump in the floor...
Users browsing this forum: Bing [Bot] and 82 guests
