wiring loom question??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=51316
Author:  minifreak1 [ Wed Mar 18, 2009 5:33 am ]
Post subject:  wiring loom question??
Well the mini is soon to return from the panel beaters.
rebuild update below
http://www.ausmini.com/forums/viewtopic.php?
t=24808&postdays=0&postorder=asc&start=15
..no new paint as yet as the funds just arnt there...the engine bay has been done so my goal is to fit the engine and the new loom and to get her running this year...so ive got a lot of time to forfill my goal.
any tips on fiting a new loom ..do they come in to pieces??
anything i should look out for..good bad ....any good places in melbourne vic to get one...
I know link automotive have a source but havent checked yet...
what kinda cost will i be loonking at?
was originaly told about $500??
Author:  Mick [ Wed Mar 18, 2009 7:09 am ]
They do come in two pieces, I would fit it as the second job after after fitting the window wiper mechanism. Feed the loom through the firewall first, and then pass the lights/engine wiring through the web near the fuse box.
Rear loom is a little more fiddly as you need to pass it through the front and rear pillars, do the front pillar first working from inside the car with a helper. Use a stiff piece of wire to push down the pillar and pull the loom through. Pass the rear part of the loom down the rear pillar and under the rear window flap catch bracket.
Author:  Austin850 [ Wed Mar 18, 2009 7:59 am ]
Just order one from Minispares in the UK. You'll probably get it in around a week for about $300 including postage.
Author:  winabbey [ Wed Mar 18, 2009 8:24 am ]
Support local industry:
http://www.vinwire.com.au/mn_list.htm
Author:  Wombat [ Wed Mar 18, 2009 10:32 am ]
Mine came from Western Australia via Northern Mini Spares, Has everything you need. Getting one locally will at least ensure it will be right for an Australian built car and help the local economy
Author:  Austin850 [ Wed Mar 18, 2009 11:06 am ]
I'm all for helping the local economy but I had quotes of between 5 and 6 hundred dollars from the two local manufacturers that I contacted. I bought exactly what I needed from Minispares for 98 pounds plus postage. (under $300 all up).
Obviously if you are doing an original restoration job on a Aussie car then it might be best to use to use someone like Vintage wiring.
Author:  floss [ Wed Mar 18, 2009 1:17 pm ]
I spoke to vinwire the other day via email and they are super helpful. they quoted me less than what austin850 has mentioned also.
Author:  minifreak1 [ Thu Mar 19, 2009 5:18 am ]
thanks for the info....
sounds like a not to hard job.
ill go back to link/and northern minis and get quotes..
ive heared there is a difference in price when you order one covered like an original item...black cotten thred???
iether way im not fussed...
Author:  Wombat [ Thu Mar 19, 2009 8:57 am ]
When I ordered mine the plastic wrap was considerably cheaper than original black cotton with the yellow fleck. I ordered plastic but when it came in it was cotton wrap. I was charged the quoted price - lucky it was written in the order book :wink:
