It is currently Fri Jul 25, 2025 11:37 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
 Post subject: Rear Flares on a Van
PostPosted: Thu Mar 19, 2009 11:42 am
just rial fitting the Incentry flares to Marcia for the Bling ones to go over the top and it seams that the seams are in a differant place to the standard Mini's
I'm guessing this is normal :roll: which would mean my bling ones would also be the same :evil:
PostPosted: Thu Mar 19, 2009 11:47 am
Did you cut that notch? I've got the same arches on the Clubman estate, and I don't think there's an issue - will check as soon as I get home.
PostPosted: Thu Mar 19, 2009 11:48 am
that's wierd Jim - I had them on my van... they should be identical to sedans
PostPosted: Thu Mar 19, 2009 11:52 am
I've never had a problem , are you sure Marcia's guards haven't been enlarged at some stage ?
PostPosted: Thu Mar 19, 2009 11:54 am
Those flares have the inner plastic sit under the steel lip on the car, not above it that's what you've done.
PostPosted: Thu Mar 19, 2009 12:05 pm
Nothing been done to the arches at all thats how they came to me
Now the plot does thicken :roll:
PostPosted: Thu Mar 19, 2009 1:32 pm
Sure does. Here's my arches which seem to fit fine:
PostPosted: Thu Mar 19, 2009 2:36 pm
You haven't got the front ones on the back have you?
:lol:
PostPosted: Thu Mar 19, 2009 3:00 pm
:lol:
:lol: NO..I'v actualy take the ones from Morris (See:Morris A Panel Thread 3rd page) and tried them also. No good also without forcing on :roll:
I know this van has had some body work done to as it has 2 Pac paint on it so I think someone has also played with the arch's not worrying about get them where they are surpose to be and now flare won't fit.
I may have to modify some old craked ones and see how it turns out :?
PostPosted: Thu Mar 19, 2009 3:16 pm
Jim I have the old set off HaHa here, you can have `em to play with. :wink:
Not cracked.
PostPosted: Thu Mar 19, 2009 3:48 pm
no cracks no tochy..I have a cra cked one here to play with :wink:
PostPosted: Thu Mar 19, 2009 6:30 pm
The rear panel joins on a van ARE different to the sedans or at least they were when I fitted the flares to my Clubman van.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Mar 19, 2009 6:47 pm
they're not supposed to be - those flares look like MK2 Cooper S type flares (right?)
I have a brand new set here I plan to fit to my traveller, you got me worried so I took a rear one out of the box and tried it, fits perfectly
PostPosted: Thu Mar 19, 2009 6:53 pm
Yup, mine are bog standard mini flares and the fit looks fine.
Sod Simon
..Marcello Im out to get you :lol:
