Rear Flares on a Van https://www.ausmini.com/forums/viewtopic.php?f=2&t=51361 |
Page 1 of 3 |
Author: | gafmo [ Thu Mar 19, 2009 11:42 am ] |
Post subject: | Rear Flares on a Van |
just rial fitting the Incentry flares to Marcia for the Bling ones to go over the top and it seams that the seams are in a differant place to the standard Mini's I'm guessing this is normal ![]() ![]() ![]() |
Author: | Angusdog [ Thu Mar 19, 2009 11:47 am ] |
Did you cut that notch? I've got the same arches on the Clubman estate, and I don't think there's an issue - will check as soon as I get home. |
Author: | simon k [ Thu Mar 19, 2009 11:48 am ] |
that's wierd Jim - I had them on my van... they should be identical to sedans |
Author: | sports850 [ Thu Mar 19, 2009 11:52 am ] |
I've never had a problem , are you sure Marcia's guards haven't been enlarged at some stage ? |
Author: | Harley [ Thu Mar 19, 2009 11:54 am ] |
Those flares have the inner plastic sit under the steel lip on the car, not above it that's what you've done. ![]() |
Author: | gafmo [ Thu Mar 19, 2009 12:05 pm ] |
Nothing been done to the arches at all thats how they came to me Now the plot does thicken ![]() |
Author: | Angusdog [ Thu Mar 19, 2009 1:32 pm ] |
Sure does. Here's my arches which seem to fit fine: ![]() |
Author: | Harley [ Thu Mar 19, 2009 2:36 pm ] |
You haven't got the front ones on the back have you? ![]() |
Author: | gafmo [ Thu Mar 19, 2009 3:00 pm ] |
Harley wrote: You haven't got the front ones on the back have you?
![]() ![]() ![]() I know this van has had some body work done to as it has 2 Pac paint on it so I think someone has also played with the arch's not worrying about get them where they are surpose to be and now flare won't fit. I may have to modify some old craked ones and see how it turns out ![]() |
Author: | drmini in aust [ Thu Mar 19, 2009 3:16 pm ] |
Jim I have the old set off HaHa here, you can have `em to play with. ![]() Not cracked. |
Author: | gafmo [ Thu Mar 19, 2009 3:48 pm ] |
no cracks no tochy..I have a cra cked one here to play with ![]() |
Author: | michaelb [ Thu Mar 19, 2009 6:30 pm ] |
The rear panel joins on a van ARE different to the sedans or at least they were when I fitted the flares to my Clubman van. ![]() |
Author: | simon k [ Thu Mar 19, 2009 6:47 pm ] |
michaelb wrote: The rear panel joins on a van ARE different to the sedans or at least they were when I fitted the flares to my Clubman van.
![]() they're not supposed to be - those flares look like MK2 Cooper S type flares (right?) I have a brand new set here I plan to fit to my traveller, you got me worried so I took a rear one out of the box and tried it, fits perfectly |
Author: | Angusdog [ Thu Mar 19, 2009 6:53 pm ] |
Yup, mine are bog standard mini flares and the fit looks fine. |
Author: | gafmo [ Thu Mar 19, 2009 6:53 pm ] |
Sod Simon ..Marcello Im out to get you ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
