This would be hard work https://www.ausmini.com/forums/viewtopic.php?f=2&t=51376 |
Author: | Wombat [ Thu Mar 19, 2009 6:11 pm ] |
Post subject: | This would be hard work |
http://cgi.ebay.com.au/Morris-Minor-Manual-Fuel-Pump_W0QQitemZ150332307536QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item150332307536&_trksid=p3286.c0.m14&_trkparms=66%3A4%7C65%3A1%7C39%3A1%7C240%3A1318 |
Author: | Morris 1100 [ Thu Mar 19, 2009 6:19 pm ] |
It needs a longer lever, preferably one with a hand grip. |
Author: | simon k [ Thu Mar 19, 2009 6:50 pm ] |
they work alright if you rig them up to some bike pedals... that's what wives are for, you get them to pump the fuel while you drive - the faster you go, the more weight they lose |
Author: | Morris 1100 [ Thu Mar 19, 2009 6:53 pm ] |
I suppose you could hook it to the camshaft and make it into a mechanical fuel pump, would that work? ![]() |
Author: | Tombo [ Thu Mar 19, 2009 7:00 pm ] |
I have one of those, Really sux when fanging it through the hills. No electric fuel pump issues though ![]() |
Author: | simon k [ Thu Mar 19, 2009 7:01 pm ] |
maybe... but where?? - the oil pump is at one end, and the timing gear is at the other - it's not like you could put it half way along |
Author: | drmini in aust [ Thu Mar 19, 2009 7:08 pm ] |
Tombo wrote: No electric fuel pump issues though
![]() Only SU pumps have electrical problems, SU = Self Unadjusting... ![]() |
Author: | Morris 1100 [ Thu Mar 19, 2009 7:12 pm ] |
simon k wrote: maybe... but where?? - the oil pump is at one end, and the timing gear is at the other - it's not like you could put it half way along
Maybe you could stick it halfway along but it would be a struggle. You would have to pull the manifold off to get near it. It would be much easier to stick it near the radiator and let the fan knock the arm to operate the pump. You would get 16 pumps per revolution depending on the fan. |
Author: | gafmo [ Thu Mar 19, 2009 7:13 pm ] |
only use Electrice none Points fuel pumps ![]() |
