Where does it go? https://www.ausmini.com/forums/viewtopic.php?f=2&t=51408 |
Author: | Tombo [ Fri Mar 20, 2009 1:41 pm ] |
Post subject: | Where does it go? |
On my 77 van, the brake pipe goes from the master to the T piece mounted to the bracket which involves the clutch hose and engine steady. My 76 clubby sedan is in pieces and there is no allowance for the T piece on the brakcet, does it go to the box section under the master or to the diagonal brace to the inner guard? |
Author: | BALLISTIC [ Fri Mar 20, 2009 1:49 pm ] |
It goes straight down from the master cylinder down to the brake switch y-peice......if i have a car here with the same set up i will take a pic and post it up for you. |
Author: | Tombo [ Fri Mar 20, 2009 1:52 pm ] |
No no, higher up than that, real close to the master. Where do i actually fit the T piece that splits the line to the back onto the car? |
Author: | BALLISTIC [ Fri Mar 20, 2009 1:58 pm ] |
it mounts ot one of the holes in the triangulated section next to the master........i'll get a photo..... ![]() ![]() i do have a picture just waiting for p/bucket to open up so i can save and post them for you |
Author: | Tombo [ Fri Mar 20, 2009 2:00 pm ] |
BALLISTIC wrote: it mounts ot one of the holes in the triangulated section next to the master
![]() Thought it might go there, i spotted a captive nut in that area. Thanks ![]() |
Author: | BALLISTIC [ Fri Mar 20, 2009 2:17 pm ] |
![]() ![]() ![]() these of any help?? |
Author: | Tombo [ Fri Mar 20, 2009 4:04 pm ] |
The top one might have helped if i could see where the brake pipe went. Heres pics of mine, on the van its easy to see the T is bolted on the bracket, no such bracket on the blue mini... The hole in the bulkhead is for the choke cable (even though i don't use them...), the small far left hole is where earths bolt to to i think it must bolt to the slightly larger hole 2nd from left... |
Author: | drmini in aust [ Fri Mar 20, 2009 4:11 pm ] |
If it's going to use a single line system, I'd just braze a nut on the firewall and screw that bolt in. ![]() |
Author: | Tombo [ Fri Mar 20, 2009 4:14 pm ] |
drmini in aust wrote: If it's going to use a single line system, I'd just braze a nut on the firewall and screw that bolt in.
![]() Nice suggestion, but then i would be damaging my pretty paint, and besides i ran out of oxygen... I think i will just bolt it to the choke hole. |
Author: | sitnlo62 [ Fri Mar 20, 2009 4:22 pm ] |
Tombo, Your missing the little bracket that is bolted on with the clutch cylinder hose to the body. Have a close look at those pics mate. Dave |
Author: | grey 64 [ Fri Mar 20, 2009 6:37 pm ] |
yeh as dave said, the piece with the vertical fold in it that your T piece goes onto is a seperate piece and is what your after. It sits on top of the bracket welded to the fire wall, under that nut. |
Author: | simon k [ Fri Mar 20, 2009 10:49 pm ] |
I'm sure I've got one somewhere I could send you Tom, but have a hunt through your bits'n'bobs - though it'd take you 2 minutes to make one with a bit of angle and a bolt & nut |
Author: | Tombo [ Fri Mar 20, 2009 11:54 pm ] |
Yeah i see that bracket now. Oh well, it's bolted to the firewall now, looks neat too. ![]() Put in fluid, bled and now it has brakes ![]() Purple fluid, dot 5 silicone fluid, stable boiling temp and wont soak moisture from the air to corrode cylinders, which are stainless sleeved now anyway. Not cheap. |
