It is currently Mon Jul 21, 2025 11:52 am
 Post subject: Got spark, fuel...
PostPosted: Mon Mar 23, 2009 9:59 am
:oops: Hey guys. Just did the head gasket with the old man. Got everything back together, push the starter and I get a spark and everything’s moving.
Pump the gas and the carbie sprayed out fuel (have the air filter off)
what da? Sorry if this is a bit vague. mega noob here!!
PostPosted: Mon Mar 23, 2009 10:49 am
sprayed fuel out of the inlet?
check the timing
PostPosted: Mon Mar 23, 2009 10:57 am
yes I believe so, ok I will check the timing. Thanks!
PostPosted: Mon Mar 23, 2009 12:11 pm
if it was running when the head came off, then the timing won't have changed in the mean time....
set the tappets correctly? got the choke linkage set properly?
PostPosted: Mon Mar 23, 2009 12:15 pm
Just a blindingly obvious one but you didn't put a bit of rag in the inlet ports while the head was off and then not get it all out before you put the manifold back on ?
PostPosted: Mon Mar 23, 2009 12:28 pm
no, i dont think so. but another valid thing to check. Thanks
PostPosted: Mon Mar 23, 2009 1:11 pm
spark plug leads around the right way?
PostPosted: Mon Mar 23, 2009 1:14 pm
Yeah the plugs are permanently numbered
PostPosted: Mon Mar 23, 2009 1:46 pm
Did you readjust the rocker clearances afterwards?
Unless the new and old head gaskets are exactly the same thickness and you numbered all the pushrods and put them in the same holes, they will need doing.
If any valves are staying open, she no go. :wink:
PostPosted: Mon Mar 23, 2009 2:38 pm
This space for rent
.. and if that's the case it'll cough back through the carb & intake when the mix is ignited.
