It is currently Sun Jul 27, 2025 8:43 am
PostPosted: Mon Mar 30, 2009 1:40 pm
hey guys, im ready t run my hydraulic handbrake lines, i just want to make sure i do it right!
big thanks to julie (kyoda) for the tips and photos she gave me.
here is a diagram of how i think its meant to be set up, :
its a quick paint diagram.
i have tried search function but only found dodgey posts!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 30, 2009 1:45 pm
Email sent
and pick looks right, just make sure you have correct size WC
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Mon Mar 30, 2009 1:47 pm
what do you mean by correct size wc?
(cheers for the email)
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 30, 2009 1:53 pm
If you have a 3/4" handbrake, you need to have smaller Wheel Cylinders
I found the ones from a Morris Minor More or Less fit, they are 7/16"
The Smallest ones are 5/8" available for MINI but for ultimate lock up POWA i use the Minor ones
- Motorkana Special
PostPosted: Mon Mar 30, 2009 8:42 pm
Apologies if readers consider this too opporrtunistic, but those interested in this handbrake related post might be interested in the fly-off handbrake kit I'm selling - see:
http://www.ausmini.com/forums/viewtopic.php?t=50992&highlight=
Matt
PS Please note that I only stand to make $15 out of this, so clearly I'm not going to make off to the Carribean with the proceeds!
'68 Deluxe w/Metro engine
PostPosted: Mon Mar 30, 2009 9:17 pm
I kept the standard proportioning valve in situ, and simply put the handbrake downstream of it... no need to move it, just add a T piece on the rear subframe.
PostPosted: Tue Mar 31, 2009 12:10 am
thanks simon, i was planning something along those lines, it was just easier to draw the way i did!
cheers mate.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Mar 31, 2009 9:48 am
I'm sure you've been told to replace the flexible lines at the back if you haven't already
also, the prop valve uses different flares (single flare) to the normal T piece off the firewall (double flare) - so either get a couple of new lines made to go from the new T piece to the flexible lines (as I did, also meant I had some extra length which was handy), or find a single flare T piece
PostPosted: Tue Mar 31, 2009 10:06 am
is this a big job to do?
PostPosted: Tue Mar 31, 2009 10:09 am
depends on your definition of 'big' - you're rebuilding and rerouting the entire rear braking system
PostPosted: Tue Mar 31, 2009 11:08 am
if i have time, hopefully ill write up a how too, as this is a question often asked.
yes simon everything will be replaced new hoses are on already, thanks for the tip about the lines
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
