Changing the By-pass hose https://www.ausmini.com/forums/viewtopic.php?f=2&t=51679 |
Page 1 of 2 |
Author: | mattsmadmini [ Mon Mar 30, 2009 4:24 pm ] |
Post subject: | Changing the By-pass hose |
with the head still on... is it possible? ![]() |
Author: | Mini_Special [ Mon Mar 30, 2009 4:26 pm ] |
Got small hands? |
Author: | sgc [ Mon Mar 30, 2009 4:28 pm ] |
Post subject: | Re: Changing the By-pass hose |
mattsmadmini wrote: with the head still on... is it possible?
![]() Yes, but be prepared for much profanity and skinning of knuckles. Or for extra enjoyment, try it on the side of the road at night in the rain. |
Author: | AEG163job [ Mon Mar 30, 2009 4:31 pm ] |
That slot in the pipe on the head side always makes me curse. I could murder whoever thought of that ![]() |
Author: | Mick [ Mon Mar 30, 2009 4:33 pm ] |
Get everything that is in your way outta there first. Top rad bracket, heater hose etc. A little extra room to move goes a long way. |
Author: | Mini_Special [ Mon Mar 30, 2009 4:40 pm ] |
Step one. have small hands step two. discard all books on subject step 3 . Have a go! step for. Be asttounded at your l33t skilz as you have done it |
Author: | sgc [ Mon Mar 30, 2009 4:43 pm ] |
Step 5. Stand back and admire your handiwork, then realise you forgot to put on the hose clamps. |
Author: | WantOne [ Mon Mar 30, 2009 4:45 pm ] |
http://www.ausmini.com/forums/viewtopic ... highlight= got to be easy... I've done it. |
Author: | mattsmadmini [ Mon Mar 30, 2009 4:50 pm ] |
with everything still in place? hahahaha i put the radiator back in the other day... (had to re-fitt elec fan) before i realised i needed a new bypass... putting it in took close to half an hour (squeeze here, bend there) finally get it in! then look down the bottom to see that the bottom radiator to engine bracket was facing the wrong way.... not happy... i think ill have a beer or 6 before i get into it... |
Author: | Mini_Special [ Mon Mar 30, 2009 4:53 pm ] |
I have done it numerous times as the supplier i was using kept getting dodgey one that never expanded far enuf. i am currently using ORTAC hose made by good year as it is nice and flexible and easy to move into pos. i found it os easier to remove rad and fan at the very least |
Author: | Morris 1100 [ Mon Mar 30, 2009 5:02 pm ] |
The easiest way to change the hose is to take off the water pump. This gives the added benefit of actually knowing the condition of the water pump. ![]() But you can easily squeeze a hose in place if you know what you are doing. I prefer to use new hose clamps that I can fit a ΒΌ" drive socket onto, it is easier to tighten awkward clamps with a socket unlike a screwdriver that will try to jump off all the time. New clamps are easier to work with than trying to re-use the 40 year old ones. Also use good quality hose and not the shoddy/dodgy/useless accordion hose that so many people fit. Other tips.. Do not ever use silicone sealant on a hose. It acts as a lubricant and the hose can slip off as you tighten up the clamps. Keep the band-aids handy. You probably should have a couple already opened to save time. ![]() |
Author: | drmini in aust [ Mon Mar 30, 2009 6:29 pm ] |
Anybody wants brass hose adaptors without a slot that won't rust, PM me. $12 each, posted. |
Author: | simon k [ Mon Mar 30, 2009 9:26 pm ] |
here's my bypass hose - it's invisible, never splits, never leaks, never needs changing, I don't have to line it up when you put the head on, and is really really cheap ![]() |
Author: | d1ck0 [ Mon Mar 30, 2009 9:29 pm ] |
simon k wrote: here's my bypass hose - it's invisible, never splits, never leaks, never needs changing, I don't have to line it up when you put the head on, and is really really cheap
![]() Love the psychedelic engine paint too ![]() Dicko |
Author: | drmini in aust [ Mon Mar 30, 2009 9:37 pm ] |
![]() I hope you drilled some holes in the thermostat, otherwise you now have NO water circulation in block and head until the thermostat opens. ![]() I have a Metro head I'm overhauling right now, that plug is coming out so it can get a `proper' Mini bypass hose fitted. ![]() |
